1971 340 build recomendations #192913
01/13/09 11:16 PM
01/13/09 11:16 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Mostly stock / restoration of a 1971 challenger 340 .
car will have stock compression, with MAYBE a mild gasket match on the stock heads and stock iron intake with a new Edelbrock AVS carb
Plan is to have 255-60-15 rear tires.more than likely 3.55 rear gears and stock exhaust,manifolds and all
What would be a good cam and torque conv combination
Re: 1971 340 build recomendations [Re: gtx6970] #192914
01/13/09 11:28 PM
01/13/09 11:28 PM
Ball Ground, Georgia
Dixie Offline
Dixie  Offline
Bill,
for what it's worth, I'm pretty happy with the cam I got from Hughes Engines for my 440. It's basically stock also. I'd call them and see what they recommend.
Good luck !
Randy
Dixie Restoration Parts
Phone -(770) 975-9898
Phone Hours: M-F 10am-5pm EST
website: www.dixierestorationparts.com
email: mail@dixierestorationparts.com
Veteran owned small business
The Best Parts at a Fair Price.
Re: 1971 340 build recomendations [Re: gtx6970] #192915
01/14/09 09:35 AM
01/14/09 09:35 AM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
If you dont mind spending about fifty dollars more than an off the shelf cam, I can get you a cam that I am convinced you will be pleased with.
I have gone high twelves in an otherwise stock (except mild pocket port) 71 340 duster with 3:55 gears.
PM me if interested.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: 1971 340 build recomendations [Re: Rapid340] #192916
01/14/09 11:51 AM
01/14/09 11:51 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Hi Bill, I would look at the Vodoo line from Lunati, i have the 220/226 @.050 475/494 lift 112cl in my RR, has lots of low to mid range and also has plenty of vacuum 17" for my power brakes. Mike
Re: 1971 340 build recomendations [Re: Rapid340] #192917
01/14/09 01:28 PM
01/14/09 01:28 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
pm sent
