Aluminum block and lifter bores #1929045
10/09/15 02:47 PM
10/09/15 02:47 PM
gulfport, ms, west mi
rowin4 Offline OP
rowin4  Offline OP
I have read a lot about aluminum blocks and push rod settings and how much blocks grow but don't seem to recall if lifter bores are affected. I have a World Products Hemi block with bushed lifter bores. Just wondering what the proper tolerance would be.
Re: Aluminum block and lifter bores [Re: rowin4] #1929100
10/09/15 03:37 PM
10/09/15 03:37 PM
Kansas, Topeka
69 lawndart Offline
69 lawndart  Offline
Kansas, Topeka
I set mine at .0010" to .0013" that's what my machine shop recommended.
Re: Aluminum block and lifter bores [Re: rowin4] #1929171
10/09/15 06:07 PM
10/09/15 06:07 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
The bushing grows less than the aluminum, so I worry more about the bushing getting loose than tolerance on the tappet. As always seems to be the case, I like wider better than tight. .0015 at the tightest, and normally .002 for me, especially with a bushing.
Re: Aluminum block and lifter bores [Re: rowin4] #1929810
10/10/15 09:25 PM
10/10/15 09:25 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Darren, did your KB blocks have non-bushed lifter bores? If so, how well did they hold up with the miles/hours of a street car?
Re: Aluminum block and lifter bores [Re: Defbob] #1930069
10/11/15 11:25 AM
10/11/15 11:25 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Have them both ways. I really prefer the bushed bores for oil control, but like I said earlier when the block gets hot, you're loosing some of your press fit with the bushings. I've been lucky so far and never had any move, but I have seen blocks where they did. Some shops will mill a half groove in the bushing and then once installed drill along side the bushing and put a roll pin in.
As far as wear, the bare aluminum bores get so much oil I've had no issues as yet. Ampco bushings are near indestructible.
