What tires for the front of my 72 Dart #192903
01/13/09 11:14 PM
01/13/09 11:14 PM
Cochise County Arizona
SPWC Offline OP
SPWC  Offline OP
When I got my Dart it had 185/75/R14 Tires on it.
It has a very original spare (Bias Ply) which is 6.95-14 which also crosses over to a 195/70/14.
I am considering as much as a 205/70/14.
The tires I have on the rear are 225/70/14.
Many of you will say to the tires on the rear on the stock steelie,I understand this,but its working(for now)
Which tire would be a better match in the front for what I have on the rear,as far as looks?
195/70/14
or
205/70/14?
Any tips or suggestions?
Re: What tires for the front of my 72 Dart [Re: SPWC] #192904
01/14/09 12:18 AM
01/14/09 12:18 AM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
195/70/14
or
205/70/14?
This is mine with the old limper wheels.
The tires are 205 14's. I like them, but everyone
has their opinion whether it's stupid or not :-)
Re: What tires for the front of my 72 Dart [Re: Dart 340] #192905
01/14/09 09:17 AM
01/14/09 09:17 AM
Newfoundland Canada
Mopar1 Offline
Mopar1  Offline
Newfoundland Canada
205's will be the better choice. The 225/70/14 is approx. 26.5" tall depending on the brand and will work on the rear. The 205 is a little lower and is an excellent fit for the front of an A body.
Re: What tires for the front of my 72 Dart [Re: Mopar1] #192906
01/14/09 08:29 PM
01/14/09 08:29 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
I have 215-70-14s on the front, 225-70-14s on the rear. Both on stock rallyes.
Re: What tires for the front of my 72 Dart [Re: AdamR] #192907
01/14/09 08:32 PM
01/14/09 08:32 PM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
Plus going with the wider tire, it gives you a little bit more contact patch to help brake with and also will help protect against curbing your rims.
Re: What tires for the front of my 72 Dart [Re: None2Slow] #192908
01/15/09 12:36 AM
01/15/09 12:36 AM
SPWC Offline OP
SPWC  Offline OP
How about a 215/70/14 on the front with the stock (skinny) steelie on the front?
Would that look ok,or would that be too much tire up front? On a stock configuration,would it rub?
Re: What tires for the front of my 72 Dart [Re: SPWC] #192909
01/15/09 12:46 AM
01/15/09 12:46 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
I think on the 70 Dart I have 215/60/14 and 245/60/14 on the stock rallyes.
Re: What tires for the front of my 72 Dart [Re: RobX4406] #192910
01/15/09 08:59 AM
01/15/09 08:59 AM
scratchnfotraction Offline
I like the drag skinnys myself
3 1/2" wide with a 165/15 tire
I would go with the smaller one you listed IMO
Re: What tires for the front of my 72 Dart [Re: scratchnfotraction] #192911
01/15/09 10:45 AM
01/15/09 10:45 AM
Columbus, Ohio
wheelsup68dart Offline
Columbus, Ohio
I used to run 205-70-14's on mine and always liked the looks. Did not do as well in the snow as the 185/70's
Re: What tires for the front of my 72 Dart [Re: wheelsup68dart] #192912
01/15/09 01:52 PM
01/15/09 01:52 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
My son runs 205/75-14's on the front of his 72 Dart. And he runs 26 x 9.5 -15 Hoosier QTP tires on the back. Ron
