Exhaust Manifold Interchange 1972 340 #1928966
10/09/15 12:46 PM
10/09/15 12:46 PM
Upstate New York
archie340 Offline OP
Upstate New York
Need to replace a cracked right side manifold on my 340 which currently has earlier manifolds off a 1970.
I found a #3751084-1 off a 73 roadrunner and was wondering if this is a direct swap for the #3418621 casting that is supposed to be correct for 71-72 models. Both the 3418621 and 3751084-1 appear identical from what I can tell.
Re: Exhaust Manifold Interchange 1972 340 [Re: archie340] #1929012
10/09/15 01:52 PM
10/09/15 01:52 PM
they both would bolt up to the eng for sure. If the outlet is in the same location/shape I'd say your good.
