Re: Manual 4 speed. Gear oil or ATF?
[Re: ColorMeGreen]
#1928643
10/08/15 10:06 PM
10/08/15 10:06 PM
Posts: 21,122 Niles , Ohio
therocks
Niles , Ohio
Some say ATF.I have used nothing but 80 90 gear oil since the 60s.My 65 thats well abused and the Express truck still have gear oil and no problems.Ma did recommend ATF in winter if shifts were hard.I drove mine for years year round in the 60s 70s and gear oil was fine.Rocky
Chrysler Firepower
[Re: ColorMeGreen]
#1928949
10/09/15 12:16 PM
10/09/15 12:16 PM
therocks
Niles , Ohio
Actually factory did recommend ATF for cold weather.Ive never used it and probally never will.After close to 45 years on my trans Its fine and shifted great even cold.Rocky
Chrysler Firepower
[Re: ColorMeGreen]
#1928950
10/09/15 12:16 PM
10/09/15 12:16 PM
Posts: 75,274 A gulag near you.
JohnRR
A gulag near you.
Castrol syncromesh works well , it designed to be used in transmissions with brass blockers
Mainstream Media is the new Pravda
[Re: terzmo]
#1929041
10/09/15 02:43 PM
10/09/15 02:43 PM
Posts: 9,066 Eugene, Oregon
minivan
Eugene, Oregon
not debating the point made but I NEVER heard of anyone saying"cold weather is coming,gotta change the tranny fluid".....just wasn't done in my area Read it all the time back in the early 70's in service manuals.. Also recommended 140 wt for 18 spline 4 speeds.. WAY TOO thick, I tried it.....
[Re: ColorMeGreen]
#1929165
10/09/15 05:54 PM
10/09/15 05:54 PM
JohnRR
A gulag near you.
If you've ever disassembled an 833 with high miles that ran only ATF you'd find the cluster gear pin will have a groove worn in it from the needle bearings due to the ATF.
[Re: ColorMeGreen]
#1929168
10/09/15 05:59 PM
10/09/15 05:59 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Always used 90 wt,never any problems.
[Re: ColorMeGreen]
#1929227
10/09/15 07:45 PM
10/09/15 07:45 PM
Posts: 259 Khemi, Stygia
Mebsuta
Khemi, Stygia
I use 80w-90. I topped it off with GL-5 a few years ago and it hasn't dissolved yet.
68 Roadrunner. 383 4-spd. Beat up.
[Re: ColorMeGreen]
#1929257
10/09/15 08:53 PM
10/09/15 08:53 PM
Posts: 12,799 Benton, IL.
DaveRS23
Master of nothing...
Benton, IL.
Gl-4 for trannys and GL-5 for diffs. There is a difference and it matters way more than the weight. DO NOT use GL-5 in your 833.
Master, again and still
