what size exhaust for a 72' 4 barrel stock 360? #1928870
10/09/15 09:35 AM
10/09/15 09:35 AM
fullmetaljacket Offline OP
I would think that at best, a 2" tube exhaust would serve best. Some guys have suggested 2-1/4 which I think is too big for a small stock lift cam with stock ports and 340 exhaust HP manifolds.
I have a set of magnaflow straight thru 2" mufflers laying around as well that I could include in the package.
What say ye?
Re: what size exhaust for a 72' 4 barrel stock 360? [Re: fullmetaljacket] #1928963
10/09/15 12:41 PM
10/09/15 12:41 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
I had a 71 cuda with a 360 and edlebrocks,had 1-7/8 hea ders and 2 in. exaust and was a real screamer shruggy
Re: what size exhaust for a 72' 4 barrel stock 360? [Re: fullmetaljacket] #1928984
10/09/15 01:16 PM
10/09/15 01:16 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I'm at 2.5" minimum preferably with an H-pipe or X-pipe to equalize each bank.
More is just overkill for your application and less IMHO isn't worth the bother.
Kevin
Re: what size exhaust for a 72' 4 barrel stock 360? [Re: fullmetaljacket] #1929044
10/09/15 02:46 PM
10/09/15 02:46 PM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
I believe factory head pipes for 340s were 2 1/4" and your manifold opening probably isn't that big. I think 2 1/4" would be plenty with what you have.
Jeff
72 Plymouth Roadrunner 11.08@123.25
Re: what size exhaust for a 72' 4 barrel stock 360? [Re: Roughbird72] #1929062
10/09/15 03:06 PM
10/09/15 03:06 PM
my own world
theraif Offline
theraif  Offline
my own world
i use 2.5 on all my stuff
Re: what size exhaust for a 72' 4 barrel stock 360? [Re: fullmetaljacket] #1929066
10/09/15 03:09 PM
10/09/15 03:09 PM
Alberta Canada
StrokerAspen Offline
Alberta Canada
Whatever size the manifolds exit at and then a single 3" up That would sound awesome I bet!
-Kenny
Re: what size exhaust for a 72' 4 barrel stock 360? [Re: StrokerAspen] #1929119
10/09/15 04:09 PM
10/09/15 04:09 PM
2&1/2" with mandrel bends & as low of restriction muffs as you can stand & resonators (glasspacks) alongside the rear springs will let you run a less restricted regular type muff(s) up front & still keep the noise down to a tolerable level. X pipe too. BEST (tho its $$$) is restricted (quiet) muffs up front and cable or elec cutouts! Constant noise is high school stuff and with cutouts with the money in a neutral parties' hands then 10 seconds later it'll all be over but the cryin (& you'll be richer). they wont know what hit em till you pull the cable/flip the switch!
Re: what size exhaust for a 72' 4 barrel stock 360? [Re: fullmetaljacket] #1929125
10/09/15 04:18 PM
10/09/15 04:18 PM
P
Paul_Fancsali Offline
P
I would use what you have you will never notice the difference A good 2" or 2.25 would work just fine If you have cam up or headers another matter. Biggest difference I saw was comp cam and headers threw a 2.25 exhaust open cutouts dropped car .3 in qtr
Re: what size exhaust for a 72' 4 barrel stock 360? [Re: fullmetaljacket] #1929276
10/09/15 09:44 PM
10/09/15 09:44 PM
Central NC
gch Offline
gch  Offline
Central NC
I say 2.25 head pipes at least but preferably all the way back.You could expand your 2" mufflers and run them to save money of you want.
An x-pipe would be my preference.
Re: what size exhaust for a 72' 4 barrel stock 360? [Re: fullmetaljacket] #1929332
10/09/15 10:55 PM
10/09/15 10:55 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
2.5 minimum on everything I own.
Re: what size exhaust for a 72' 4 barrel stock 360? [Re: RV2] #1929340
10/09/15 11:07 PM
10/09/15 11:07 PM
Thanks guys. Going 2-1/4 from the head exhaust all the way back.
This is a bone stock 360 with nothing else other than 340 exhaust manifolds.
