99 Dakota R/T Brakes
#1928592
10/08/15 08:48 PM
10/08/15 08:48 PM
moparpollack
Lil Herman
Lil Herman
85086
What would cause the front rotors to lock tight on the rotor? The master cylinder had pressure in it when I removed the lid. When it cools down I will release the banjo bolts to see if the calipers are stuck. I could see one being stiff but not both of the fronts being stuck. The ABS light is not on I've never dealt with an ABS system before.
Re: 99 Dakota R/T Brakes
[Re: poorboy]
#1928696
10/08/15 11:22 PM
10/08/15 11:22 PM
moparpollack
Lil Herman
Lil Herman
85086
yup new pads about 50 miles ago but everything was fine.
[Re: ahy]
#1929464
10/10/15 09:08 AM
10/10/15 09:08 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Typical in these trucks. Rubber hose deteriorates from inside out. Gunk fills caliper, caliper seizes. Replace calipers and hoses and it fixes the issue most of the time.
**Photobucket sucks**
