Page 2 of 3 1 2 3
Re: 3D Printers are Fun! Gen 3 Hemi Roller Rockers [Re: onig] #1856528
06/25/15 12:10 PM
06/25/15 12:10 PM
Smyrna, South Carolina
STEFF Offline OP
STEFF  Offline OP
Originally Posted By onig
That is so cool.
Any design changes on your belt drive or updates?
The Belt Drive has shown to work flawlessly!! I want to make a couple small changes to be a little more user friendly.
Re: 3D Printers are Fun! Gen 3 Hemi Roller Rockers [Re: STEFF] #1856647
06/25/15 02:17 PM
06/25/15 02:17 PM
dogdays Offline
dogdays  Offline
Great that you're making stuff for the GIII.
I have one nagging question, though...Isn't the best valve action obtained from having the rocker/pushrod angle to be 90 degrees at full lift? IIRC that gets the valve off the seat faster, so the valve is open longer. Or is this an area where best practice has changed? I mean, you are in the heart of NASCAR country and they do obscene testing.....
R.
Re: 3D Printers are Fun! Gen 3 Hemi Roller Rockers [Re: STEFF] #1856770
06/25/15 05:00 PM
06/25/15 05:00 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
I would have liked to see a 1.7-1.75 ratio rocker. Still nice work as always Steff
Re: 3D Printers are Fun! Gen 3 Hemi Roller Rockers [Re: sixpackgut] #1857487
06/26/15 05:01 PM
06/26/15 05:01 PM
STEFF Offline OP
STEFF  Offline OP
I may be able to do a 1.7 ratio for the prototypes on my heads. Need to check spring installed heights.
Re: 3D Printers are Fun! Gen 3 Hemi Roller Rockers [Re: STEFF] #1862054
07/02/15 02:52 PM
07/02/15 02:52 PM
Ohio
Hemi31 Offline
Hemi31  Offline
Ohio
Oh man when?! Was on a search for Arrington rollers but another option would be great. Will they clear the big retainer from the dual valve springs? The T&D was an option till I found out the wouldn't clear. Would be nice to be able to do .700 lift at the valve without spending $10k on a Jesel.
Re: 3D Printers are Fun! Gen 3 Hemi Roller Rockers [Re: STEFF] #1862715
07/03/15 11:08 AM
07/03/15 11:08 AM
Indianapolis In. usa
Quickrunner Offline
Quickrunner  Offline
So when you putting all this cool eye candy into production and selling it to us? smile
05 Ram 1500 Daytona package
71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
Re: 3D Printers are Fun! Gen 3 Hemi Roller Rockers [Re: STEFF] #1928266
10/08/15 11:19 AM
10/08/15 11:19 AM
cedar rapids, iowa
superhog88 Offline
superhog88  Offline
cedar rapids, iowa
Any updates on the rockers
Re: 3D Printers are Fun! Gen 3 Hemi Roller Rockers [Re: STEFF] #1928284
10/08/15 12:05 PM
10/08/15 12:05 PM
New York
polyspheric Offline
polyspheric  Offline
New York
90 degrees at full lift is slower from closed, and has smaller area under the curve.
Just a guess: the 12 degree correction isn't because the OEM parts are bad - the 90 degree/50% lift is the best plane geometric model, but not necessarily the best rocker arm. Pallet rocker don't use it to get some anti-scrub effect.
Boffin Emeritus
Re: 3D Printers are Fun! Gen 3 Hemi Roller Rockers [Re: STEFF] #1928414
10/08/15 03:16 PM
10/08/15 03:16 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
90 degrees at zero lift gives you fastest off the seat valve action and least lift at max lift.
90 degrees at open gives you most total lift and softest touchdown on the seat but it is hard to keep the valve from losing contact with the rocker tip.
90 degrees at mid lift (or somewhere close depending on who you talk to) gives you the best of everything.
Anywhere except 90 degrees rocker/valve relation will give less than max ratio. Don't forget that if you have a roler tip than the (theoretical) tip of the valve is actually going to be the center of the roller.
Re: 3D Printers are Fun! Gen 3 Hemi Roller Rockers [Re: STEFF] #1928424
10/08/15 03:30 PM
10/08/15 03:30 PM
New York
polyspheric Offline
polyspheric  Offline
New York
My point: the largest possible area (average lift X degrees open) as a math model isn't always what the engine wants, or what provides the best service life for the parts.
500 years ago, Warren Johnson (yes, the same guy) adjusted the rockers on his Olds for higher lift early in the event to get closer to the piston's maximum velocity = highest vacuum.
Note: no, the ICL can't be at the stroke's midpoint without very bad results.
Vizard has been doing some interesting work comparing BBC rockers that (are designed to and/or adjusted to) produce high lift very quickly.
Boffin Emeritus
Re: 3D Printers are Fun! Gen 3 Hemi Roller Rockers [Re: superhog88] #1928605
10/08/15 09:07 PM
10/08/15 09:07 PM
STEFF Offline OP
STEFF  Offline OP
Prototypes are being machined.
Re: 3D Printers are Fun! Gen 3 Hemi Roller Rockers [Re: STEFF] #1928681
10/08/15 10:56 PM
10/08/15 10:56 PM
cedar rapids, iowa
superhog88 Offline
superhog88  Offline
cedar rapids, iowa
What's the max lift you are looking to handle
Assuming steel as the material but if they work out will you consider aluminum for lighter duty engines
How do you test them assuming on an engine of course but are there other test or is there such a thing as a dyno for rocker gear
Thanks for the info steve
Re: 3D Printers are Fun! Gen 3 Hemi Roller Rockers [Re: superhog88] #1928865
10/09/15 08:41 AM
10/09/15 08:41 AM
STEFF Offline OP
STEFF  Offline OP
I ended up with a 1.72 ratio on the intake rockers and 1.68 on the exhaust. I have a .410" lobe. With lash, looking at about .691" lift on the intake and about .670" on exhaust. Material is steel. No plans to experiment with aluminum. I designed them to clear a 1.300" dia. LS dbl. valve spring. Testing is putting them on my own motor and let er' rip!! What ever happens, happens....good or bad. It's the only way you learn things.
Re: 3D Printers are Fun! Gen 3 Hemi Roller Rockers [Re: STEFF] #1928921
10/09/15 11:28 AM
10/09/15 11:28 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Steff that is just awesome.
Mopar to the bone!!!
Re: 3D Printers are Fun! Gen 3 Hemi Roller Rockers [Re: STEFF] #1928965
10/09/15 12:44 PM
10/09/15 12:44 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
so are you thinking the springs were your problems? You really cant run a dual valve spring on the newer heads because of the boss is holding the guide on top instead of in the port like the 6.1 heads. But you can fit much bigger behives on the newer heads
Re: 3D Printers are Fun! Gen 3 Hemi Roller Rockers [Re: superhog88] #1929083
10/09/15 03:22 PM
10/09/15 03:22 PM
Alberta Canada
StrokerAspen Offline
Alberta Canada
It sounds like STEFF is using the companion software to Solid Works called Simulation I am assuming. I have used Simulation for many engineering projects in the past. It is a very powerful and accurate program, that is about the best testing you will get from a design side of things. If I was a betting man, I would say if STEFF has all the bases covered, which it looks like that is the case, there will be no surprises with the prototypes when they are tested in real life application.
-Kenny
Re: 3D Printers are Fun! Gen 3 Hemi Roller Rockers [Re: STEFF] #1929202
10/09/15 07:09 PM
10/09/15 07:09 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
Good work there. Do you happen to know the offset of the intake rockers and the angle between the intake valve and pushrod?
Here's some pics of my latest project for my Gen 3 Hemi. I designed up some Roller Rockers.
[/IMG][/IMG]
While I don't agree that testing is the only way to learn things it is a necessary part of the design process, and fun too!
Re: 3D Printers are Fun! Gen 3 Hemi Roller Rockers [Re: STEFF] #1969323
12/14/15 03:08 AM
12/14/15 03:08 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
KOOL...
Re: 3D Printers are Fun! Gen 3 Hemi Roller Rockers [Re: rowin4] #1969438
12/14/15 02:15 PM
12/14/15 02:15 PM
IMGTX Online content
IMGTX  Online Content
Originally Posted By rowin4
Google you tube Joseph de Simone 3 -d printers are now antiques
His process is already commercially available here.
http://formlabs.com/
What he has done is a better job of refining the laser/resin printing. Luckily that technology has lost its patent (expired do to age of patent) this past February so it has become open technology.
A lot of exciting things can happen with 3d printing technology that most people don't think about. I don't have time to go into all the details but it has the potential to do more than just make prototype parts. I teach this stuff and your talking Environmental impact, lifestyle changes, innovative design princples. Imagine a world where you create mechanical designs or art that can be sold or shared like music on an Ipod.
I will tell you what will determine the presiding 3D manufacturing technology and it won't be what is best. In a few years Amazon/Walmart/Target/ etc will find a technology that will allow them to lease you a 3D printer the likes of which you could never afford. They will do it for cheap/free so they can sell you stuff online and no shipping cost for them except the supplies they may have to send you once a month. Once they latch on to something, better technology will be ignored in the face of profit margins. Think about Betamax vs VHS, the better lost and the higher profit margin product won.
Re: 3D Printers are Fun! Gen 3 Hemi Roller Rockers [Re: STEFF] #1971176
12/16/15 11:51 PM
12/16/15 11:51 PM
Vermont
TrWaters Offline
TrWaters  Offline
Vermont
I am glad to see that my rocker shaft collar design is still in use. up
TR Waters
Page 2 of 3 1 2 3
