coil confusion #192835
01/13/09 10:38 PM
01/13/09 10:38 PM
New York
K
Ken25 Offline OP
Ken25  Offline OP
K
New York
a friend told me on the old mopar ignition coils that with age can produce a weaker spark. i've only seen them work or not.can a old coil give a week spark?whats a stock voltage? thanks
Re: coil confusion [Re: Ken25] #192836
01/13/09 11:06 PM
01/13/09 11:06 PM
Va. Beach, Va
69superbee383 Offline
Va. Beach, Va
I have had the oil leak out of them as they get old. And they will produce a weak almost orange spark and yet still work
77 Macho Power Wagon LWB factory 440 70 Coronet 440 N code 3 speed
Re: coil confusion [Re: Ken25] #192837
01/14/09 12:52 AM
01/14/09 12:52 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Think of the coil as a step-up transformer..
Takes the 12V up to xx kv..
Inside it has many, many turns of enameled wire sitting in a round cylinder case with oil..
The oil bath is for cooling..
Over the years the enamel wire coating can degrade effectively shorting out some of its turns. This will reduce the coil's output voltage..
