Transmission mount question #1928125
10/08/15 01:12 AM
10/08/15 01:12 AM
USA
440mopar Offline OP
440mopar  Offline OP
USA
The original transmission crossmember and mount for my Dart is of the biscuit type. I will be putting the trans. back in soon and was wondering whether I should change it to a later model spool mount crossmember when I do. What I would like to know is, is there any real benefit to using a spool mount over a biscuit mount on the trans.? I know the spool type mounts are preferred on engine crossmembers but haven't ever heard one way or the other regarding trans. crossmembers.
Re: Transmission mount question [Re: 440mopar] #1928294
10/08/15 12:16 PM
10/08/15 12:16 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
The only advantages I can see are trans bolt easier bolt access and poly mount availability ?
Re: Transmission mount question [Re: 440mopar] #1928418
10/08/15 03:22 PM
10/08/15 03:22 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The trans spool mount is better for the same reasons the spool engine mounts are better.....captivity upon failure.
