a body 8 3/4 in 76 dart?
#192797
01/13/09 10:00 PM
01/13/09 10:00 PM
Posts: 377 Michigan Troll
blk00rt
Michigan Troll
I have a 76 dart sport and trying to put a a body 8 3/4 in it. It appears that the spring perches are about 1 to 1 1/2" off. I looked in the tech articles and it says that the 8 3/4 for a bodies were about 1.8" wider than the 7 1/4. What did you guys do, loosen the spring mounting bolts and get the perches to line up or buy new perches and weld them on?
Rob Dunn 1976 Dart Sport 360 2000 dakota RT 408 with 150 nitrous 2013 Dodge Ram 1500 Hemi 2009 Jeep Patriot
Re: a body 8 3/4 in 76 dart?
[Re: MoparforLife]
#192799
01/13/09 10:17 PM
01/13/09 10:17 PM
Posts: 20,176 Park Forest, IL
slantzilla
Park Forest, IL
If the spring perches are too far apart you do not have an A-body rear. Most likely a B body. Measure it for overall width against the stock rear.
[Re: MoparforLife]
#192801
01/13/09 10:41 PM
01/13/09 10:41 PM
blk00rt
Michigan Troll
thanks, I just ordered the spring perches..looks like another week end project for me.
[Re: scratchnfotraction]
#192805
01/14/09 09:54 AM
01/14/09 09:54 AM
Posts: 10,968 Hampton, Ga.
70dart360
Green Meister
Green Meister
Hampton, Ga.
If its the smallbolt pattern its an a-body, if not, sounds like a B body rear.
70 Dart Swinger
72 D-100 440 shortbed
76 Pinto, 68k 21mpg!
#192806
01/14/09 07:13 PM
01/14/09 07:13 PM
blk00rt
Michigan Troll
it was sold to me as an a body rear end with large bolt pattern axles. from the spring perches I think it might be a b body. Oh well its going to fit and I will just weld on new perches this weekend. thanks for your help
[Re: blk00rt]
#192808
01/15/09 02:12 AM
01/15/09 02:12 AM
Posts: 10,693 Surface of the Sun, AZ
Hotwheelsjr
I hope you didn't PAY for an a-body rear -- they're a bit steeper in price than B/E body ones due to their demand and lack of supply. In your case, not knowing the measurements of an a-body rear, I'd be ticked if I didn't get what I was paying for.
[Re: Hotwheelsjr]
#192809
01/15/09 08:56 AM
01/15/09 08:56 AM
Posts: 15,487 Florida
scratchnfotraction
again..the B-body 8 3/4 will fit with moving the perches but the rims will need to have some more back set to fit in the wheel wells and not rub the fenders lips so ya gonna need some rims to go with it I had one cut down to A-body specs and used the moser axles with green bearings that made the whole rear a 1/2 wider..1/4 each side and used 4 1/2" backset on 7" rims in a 68 Dart you will need to have more than 4 1/2" so measure carfuly
