Re: 1968 Dodge Dart fiberglass door recommendations?
[Re: WS68SSC]
#1928056
10/07/15 11:28 PM
10/07/15 11:28 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Glasstek makes a real nice set. I saw them in person on Jason Digby's car.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#1928162
10/08/15 02:55 AM
10/08/15 02:55 AM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
A pair of doors by the time your done with the fitting,dealing with windows and paint will be over $2000.If you gut the steel ones it might be a 40 lb difference.
[Re: WS68SSC]
#1928230
10/08/15 10:17 AM
10/08/15 10:17 AM
1967dartgt
Hilltown Pa
Digby's doors were 10lbs ea with the lexan. He also made them pin on and off with light weight hinges, it's closer to 40 lbs a door difference from gutted steel doors.
[Re: WS68SSC]
#1928706
10/08/15 11:29 PM
10/08/15 11:29 PM
1967dartgt
Hilltown Pa
They maybe carbon, I picked them up and had very little weight to them. Didn't think glasstek made carbon stuff.
[Re: 1967dartgt]
#1928721
10/08/15 11:45 PM
10/08/15 11:45 PM
Posts: 22,719 Bitopia
jcc
Bitopia
Hand lay up carbon fiber is nearly identical process to fiberglass, except for the cost and weight. I would think most vendors will do Cf, if you ask, and are willing to pay a hefty surcharge, which is more for the hassle, then the actual extra material costs, IMO.
[Re: dvw]
#1928826
10/09/15 02:28 AM
10/09/15 02:28 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Are they carbon? No way a glass door,lexan,and latch/release,paint is only 10lbs.
Doug Wrong.........our glass G-body doors, with frames, door panels(carbon), lexan and even the stock outer door handles are barely over 10lbs each. They are Glasstek. And I would think a G-body door is bigger than a Dart door Our TOTALLY gutted steel doors with factory glass was 85lbs a side
[Re: Monte_Smith]
#1929605
10/10/15 02:00 PM
10/10/15 02:00 PM
Posts: 9,871 MI, usa
dvw
MI, usa
Doug Wrong.........our glass G-body doors, with frames, door panels(carbon), lexan and even the stock outer door handles are barely over 10lbs each. They are Glasstek. And I would think a G-body door is bigger than a Dart door Our TOTALLY gutted steel doors with factory glass was 85lbs a side They must make some pretty thin stuff. That's amazing. Nice to see an aftermarket part that's that nice and barely over 10lbs. I'm surprised the stock gutted door was that heavy. My stock untouched 64 Belvedere post doors loaded were 75lbs. Doug
