Re: Strange S60 rebuild Qs
[Re: Publicbottle]
#1928296
10/08/15 12:19 PM
10/08/15 12:19 PM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
The nice thing about the S60 is it uses a threaded adjuster so getting the center in and out is easier. You need to find out what tool is required and obviously get that one. Measure the current backlash and reset it as close as possible when putting it back together ...
Oh and get a better sure grip , the track lock is not very robust ...
[Re: JohnRR]
#1928318
10/08/15 01:01 PM
10/08/15 01:01 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I wish that I had an S60. All my experience is with the Dana 60 and I once spent a whole weekend loading the carrier in and out of the housing to get the pattern right. At least I had a kit with setup bearings and did not have to press them on & off. Now I have an OTC Case Spreader and can pop the carriers in and out properly. The best new LSD is the Eaton geared unit, no special lube required. JMHO
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Publicbottle]
#1928371
10/08/15 02:29 PM
10/08/15 02:29 PM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
Having the wrong oil (wrong friction modifier) will cause what you're describing. Try putting a bottle of the Ford Motorsport limited slip additive in it before you rebuild it.
[Re: Publicbottle]
#1928444
10/08/15 04:01 PM
10/08/15 04:01 PM
an8sec70cuda
The Ford additive is what Dr. Diff recommends. I had the same issue w/ the Powerlock in the Dana I built for my dad's road runner. It chirped, popped, and made a racket until I put the Ford additive in there. That stuff works.
No problem reusing your ring and pinion. You're just changing the differential...just swap the ring gear onto the new diff. and set your backlash.
