I installed my brace yesterday. Mine is a 2WD diesel. I had to grind a little half moon on the top of the plate just behind the forward most bolt hole for frame clearance. Not a big deal and it's only about the radius of a quarter.
I did not have to drill the front cross support though as it was already slotted there. I couldn't find 1.75" long bolts so I used 2" bolts and they fit just fine.
Thanks for getting these made again!
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
