Restricting BB lifter galley oil to increase oil pressure
#1926938
10/06/15 11:42 AM
10/06/15 11:42 AM
BradH
Somewhere on here in the past, someone posted how they inserted a metal rod down in the oil galley passage on the back of the block that intersects the driver's side(?) lifter galley passage. This is the same galley passage some people either plug off entirely, or put a plug w/ a small hole in.
The rod was described as having been turned down enough to allow for oil to get around it, but still large enough to act as a restrictor for the lifter galley passage. By doing this, the poster was able to get the idle oil pressure back up to something more "normal", which IIRC they said had dropped dramatically as the result of using roller lifters having cut-away bands in the bodies.
Instead of bushing the lifter bores, is this a reasonable "cheap fix" to use if the style of the roller lifter body may expose too much of the lifter galley and, as a result, drop the oil pressure? I know the IMM lifters I own, and similar COMP lifters, have been used successfully in unbushed blocks (440Jim, Brian at IMM), but once in a while there have been posts by people (such as the one I'm referring to) who have used the COMP cut-away lifter and did experience oil pressure loss. Thanks - Brad
Re: Restricting BB lifter galley oil to increase oil pressure
[Re: Cab_Burge]
#1927121
10/06/15 04:00 PM
10/06/15 04:00 PM
BradH
No way I owuld put a straight rod big enough inside the oil galley to restrict the oil pressure with either a straight body or a set of roller lifters like yours with the cutaway body, they both would rub on the rod That's not what I'm asking about. The channel in the back of the block that feeds the oil pressure sending unit also happens to intersect the lifter galley (or is it gallery?). The guy I remember put a thin metal rod down THAT channel, not one all the way through the lifter galley (or is it gallery?). Big difference! The drilled plug idea works, too. I think the person who did the rod trick wasn't sure what diameter to make it, so he could remove it w/ a magnet if necessary to change its diameter.
[Re: Stanton]
#1927294
10/06/15 08:58 PM
10/06/15 08:58 PM
BradH
The lifters in your photo don't have enough of a shroud and will expose the galley on a .600 lift cam (had the same issue). Not according to Brian at IMM (those are his lifters shown) and 440Jim (who ran the comparable COMP 892 version). I haven't seen any solid lifter bodies that shroud the wheel any more than these, either. Any pics you can provide of ones that do would be of interest. Thanks - Brad
[Re: BradH]
#1927480
10/07/15 01:20 AM
10/07/15 01:20 AM
Posts: 485 Central California
MoParFish
Central California
Brad, I think it was me you are referring to. I responded to a post by Rebel a while back and posted what I did, with pics. Worked great for me and, I also did the same mod to a buddy's engine also worked well. I can remove the modification in about 5 minutes if needed... Here's a link to the thread, scroll down to see posts and pics...Mike https://board.moparts.org/ubbthreads/ubbt...tml#Post1659270
