removable trans tunnel? #1927377
10/06/15 10:11 PM
10/06/15 10:11 PM
South Dakota
dakotahotrodder Offline OP
South Dakota
I would like to put in a removable trans tunnel in my '67 Belv. It's backhalved with a stock firewall and tunnel/floor. I am still using the stock cable accelerator pedal, but will change it over if I need room. I am sick of fighting this area when I have to get to the bellhousing bolts. Any pictures of what you guys have done would be cool. Thanks
Re: removable trans tunnel? [Re: dakotahotrodder] #1927386
10/06/15 10:18 PM
10/06/15 10:18 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Man you got it easy....I just pulled the 512 out of my Duster and it has a CSR sheild on the 727 with a stock firewall...I said more curse words this past week in the garage than most truck drivers in the same time frame. Not to mention the fender well headers....So I am also open to modified trans tunnel ideas, maybe even more than you....My Cuda is a breeze with a big Hemi and big tube headers.
Re: removable trans tunnel? [Re: dakotahotrodder] #1927411
10/06/15 10:53 PM
10/06/15 10:53 PM
WA
JD Dart Offline
JD Dart  Offline
WA
Stock firewall stock floor board unibody car that is its structure.
It will destroy the car only way I would do it put in a doubler around the entire perimeter nut plates every 2 inches min not zus fasteners put screws or bolts back in the cover plate wild guess that’s about 45 screws the cover plate will have compound curves you will have to stretch and shrink the metal in order to make it.
Can it be done yes, maybe it would be easier to come up with newer cuss words.
best so far 8.53 @ 158.59 MPH 60'1.240
Re: removable trans tunnel? [Re: Dragula] #1927421
10/06/15 11:05 PM
10/06/15 11:05 PM
South Dakota
South Dakota
Man you got it easy....I just pulled the 512 out of my Duster and it has a CSR sheild on the 727 with a stock firewall...I said more curse words this past week in the garage than most truck drivers in the same time frame. Not to mention the fender well headers....So I am also open to modified trans tunnel ideas, maybe even more than you....My Cuda is a breeze with a big Hemi and big tube headers. [/quote]
Same here with the CSR shield. I was going to just put some holes in the firewall where the bellhousing bolts are but the shield is still way tight in the tunnel.
Re: removable trans tunnel? [Re: JD Dart] #1927427
10/06/15 11:10 PM
10/06/15 11:10 PM
South Dakota
South Dakota
Stock firewall and floor up front yes, but backhalved and connectors to the front frame with a 12 point 8.50 cert. cage tying it all together.
Re: removable trans tunnel? [Re: dakotahotrodder] #1927430
10/06/15 11:14 PM
10/06/15 11:14 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
I needed something for the weekend a few years back so I threw this together in a few hours, I haven't changed it since it's pretty effective and passes tech. I'd like to make a nice one some day.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: removable trans tunnel? [Re: dakotahotrodder] #1927436
10/06/15 11:18 PM
10/06/15 11:18 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I cut mine out on my 64 Belvedere. It is not removable. Made it wider and taller. I cut the hole rolled a piece of sheet metal and stuffed it up into the hole from the bottom. Tack welded and trimmed off the excess. Then finish weld. Easy, the stock pedal is still there, and a CSI aluminum shield fits. My motor is up and back , still easy access.
Doug
Re: removable trans tunnel? [Re: DemonDust] #1927437
10/06/15 11:20 PM
10/06/15 11:20 PM
South Dakota
South Dakota
There's an option! up
Re: removable trans tunnel? [Re: dakotahotrodder] #1927461
10/06/15 11:46 PM
10/06/15 11:46 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
two piece. splits down the middle held together with 2 dzus fastners. this was the route I chose to take as the back part of the CSR shield was hitting the floor. Prior to this we had holes in the floor that we could access the bell bolts. This is easier yet.
Re: removable trans tunnel? [Re: dakotahotrodder] #1927664
10/07/15 11:28 AM
10/07/15 11:28 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Easiest: cut one out of a donor car, as big as possible (cut into the floor all around).
Remove yours 2" inboard of this outline all around.
Center the overlap etc.
If you have enough fasteners the rigidity will be quite good.
Boffin Emeritus
Re: removable trans tunnel? [Re: dakotahotrodder] #1927714
10/07/15 12:52 PM
10/07/15 12:52 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Even in a stock floor pan car, if the stock floor and tunnel is an integral part of the structure of the car, you need some more tubing in the car, because in a race car, the sheetmetal should be just that, sheetmetal.
I had big holes in my GTX that I had cut in there with a hole saw and ran rubber plugs in those holes.........but later put a removable tunnel in it to keep the firewall solid in case of fire
Re: removable trans tunnel? [Re: Dragula] #1927986
10/07/15 08:37 PM
10/07/15 08:37 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
I'll bet I can keep up with anybody on the cussing,,,, '68 Valiant, RB, 727, TTI, all stock front suspension/steering, with ARE motor plate. I'm wondering if an 8 point roll bar will pass tech with firewall/floor board/tunnel modifications???
If you like drag racing, support your local track.
Re: removable trans tunnel? [Re: J_BODY] #1927999
10/07/15 09:00 PM
10/07/15 09:00 PM
Dragula Offline
Dragula  Offline
That looks really nice. I am saving that picture and I want to see if one of the local chassis guys can do that....He just did my door panels and that would blend right in.....
In my Duster, its not that I need a bigger tunnel, I literally can not get at the bolts. I either need holes in the firewall or a removable piece I can access the bolts thru. The back of the engine is right up to the firewall.
Re: removable trans tunnel? [Re: dakotahotrodder] #1928074
10/07/15 10:52 PM
10/07/15 10:52 PM
Seminole County FL to Plymouth...
Barry70GTX Offline
Barry70GTX  Offline
You sure are making a job harder than it really is.
I stand back by the tail housing with a 9/16 flex socket on a long extension and run them in or out in less than 2 minutes.
If I need them out sooner, I grab the impact.
BTW Drop the cross member out, it makes it real easy.
NMCA NSS 67 Coronet
Re: removable trans tunnel? [Re: Barry70GTX] #1928089
10/07/15 11:15 PM
10/07/15 11:15 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Stock floor I drilled 4 holes though the f1rewall and got at them from inside the car. With the new chassis tunnel is removable.
scope
Re: removable trans tunnel? [Re: dakotahotrodder] #1928134
10/08/15 12:42 AM
10/08/15 12:42 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Once you have all the metal and fasteners doped out, don't quit too soon.
Every metal-to-metal seam should be gasketed; adhesive-backed foam is easy & cheap. Use a 1/8" thick by 1/2" wide Frost King, 3M, etc. on both sides, it will generally come apart a few times before you have to replace it.
If you don't?
The first high MPH pass fills the interior (and the back of the dash, and the gauges) with dirt.
Boffin Emeritus
