Re: 72 Bbody clutch safety switch
[Re: sogtx]
#1927511
10/07/15 02:43 AM
10/07/15 02:43 AM
Posts: 18,680 Fresno, CA
Jim_Lusk
Fresno, CA
Fuel injected now ... Leave it to me .. Rubber bumpers dont come cheap ... FI doesn't matter, it's still hard on the thrust bearing. There's a reason Chrysler did not use them in the 60s and then again in the 80s...I'd fab up a neutral switch on the shifter before I'd ever run a clutch switch...BUT I've never felt the need for one, especially after losing a thrust bearing in a 273 many years ago...
[Re: Jim_Lusk]
#1927539
10/07/15 07:20 AM
10/07/15 07:20 AM
Posts: 5,180 upstate western ny
sogtx
upstate western ny
Ok .. I guess ill fab up a different method to be cautious . I just figured that the fi engine is going to zip to life little quicker than normal . If anyone has ever used a different method , id appreciate Some examples or methods ....
[Re: Pynzo]
#1927926
10/07/15 07:38 PM
10/07/15 07:38 PM
sogtx
upstate western ny
That's the whole reason because of the dementia problems is to remember putting it into neutral- screw the switch Id put a paperclip in between the connectorsif i had a problem with the switch Lol ..
[Re: Pynzo]
#1928032
10/07/15 10:53 PM
10/07/15 10:53 PM
Posts: 7,664 IN
ahy
IN
Just run a wire from starter relay to ground, or get a pre '70 manual trans starter relay for the cleanest look. My '08 JK Wrangler has a clutch switch and I'm glad for it. And I never had an issue with the T. O. Bearing on my Bee with the clutch switch so will be reinstalling it just because it's supposed to be there. If you're not using the reverse lockout, just pull it into neutral before putting in the key. Starter relay to ground works for me for both clutch and NSS. Agree why do you need it?
[Re: Pynzo]
#1928181
10/08/15 04:05 AM
10/08/15 04:05 AM
Jim_Lusk
Fresno, CA
Just run a wire from starter relay to ground, or get a pre '70 manual trans starter relay for the cleanest look. My '08 JK Wrangler has a clutch switch and I'm glad for it. And I never had an issue with the T. O. Bearing on my Bee with the clutch switch so will be reinstalling it just because it's supposed to be there. If you're not using the reverse lockout, just pull it into neutral before putting in the key. It's not the throwout bearing that it's an issue with, it's the thrust bearing in the engine.
[Re: sogtx]
#1928223
10/08/15 10:01 AM
10/08/15 10:01 AM
Posts: 1,386 Philadelphia PA
Pynzo
Drugs are bad
Drugs are bad
Philadelphia PA
That's the whole reason because of the dementia problems is to remember putting it into neutral- screw the switch Id put a paperclip in between the connectorsif i had a problem with the switch Lol .. Put one of these on your shifter-
[Re: sogtx]
#1928225
10/08/15 10:06 AM
10/08/15 10:06 AM
Posts: 9,066 Eugene, Oregon
minivan
Eugene, Oregon
Change in Harleys to fuel injection around 2000.. Started using my clutch everytime before starting ( I know different mechanicals) when I witnessed a fuel injected bike start in gear and watched it climb a chain link fence at the Harley dealer.. Just didn't want to die with fuel injection..
It was a bad day for someone.....
[Re: Pynzo]
#1928286
10/08/15 12:09 PM
10/08/15 12:09 PM
Posts: 75,098 A Banana Republic near you.
JohnRR
After reading all the posts and reading your responses it only makes sense for you to pony up the money and buy the switch.
When I do a motor for a car with a clutch I modify the thrust bearing bearing so it pushes a pressurized oil stream back on that surface just for the concerns some have stated above.
[Re: Pynzo]
#1928452
10/08/15 04:19 PM
10/08/15 04:19 PM
sogtx
upstate western ny
That's the whole reason because of the dementia problems is to remember putting it into neutral- screw the switch Id put a paperclip in between the connectorsif i had a problem with the switch Lol .. Put one of these on your shifter- See my post somewhere about how to customize a lift off hood ...
[Re: JohnRR]
#1928514
10/08/15 06:31 PM
10/08/15 06:31 PM
sogtx
upstate western ny
When I do a motor for a car with a clutch I modify the thrust bearing bearing so it pushes a pressurized oil stream back on that surface just for the concerns some have stated above. Thats a pretty slick - when i blow up this 6.1 im bringin it over John..
