Super comps and plug wires...which wires to use? #1926800
10/06/15 02:41 AM
10/06/15 02:41 AM
US
BLACK71 Offline OP
BLACK71  Offline OP
US
Ordered a set of Taylor wires for my 440 from summit and ...go figure.... They won't work with my supercomps..what have you guys found to be the best bet?
RMNS 10:9-10
Re: Super comps and plug wires...which wires to use? [Re: BLACK71] #1926913
10/06/15 11:15 AM
10/06/15 11:15 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I only run cut-to-fit wires now, and add ceramic plug boots as an additional safety factor when the boot-to-header clearance is too tight to keep from toasting the traditional plug boot.
Re: Super comps and plug wires...which wires to use? [Re: BLACK71] #1926923
10/06/15 11:26 AM
10/06/15 11:26 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Which ones did you order that won't work?
Re: Super comps and plug wires...which wires to use? [Re: BLACK71] #1926980
10/06/15 12:33 PM
10/06/15 12:33 PM
US
BLACK71 Offline OP
BLACK71  Offline OP
US
74072...6x 90* 2x 135* boots
RMNS 10:9-10
Re: Super comps and plug wires...which wires to use? [Re: BLACK71] #1927021
10/06/15 01:38 PM
10/06/15 01:38 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Firecore`s here..............
Re: Super comps and plug wires...which wires to use? [Re: BLACK71] #1927127
10/06/15 04:14 PM
10/06/15 04:14 PM
US
BLACK71 Offline OP
BLACK71  Offline OP
US
Any issues with header clearance with the firecores?
RMNS 10:9-10
Re: Super comps and plug wires...which wires to use? [Re: BLACK71] #1927161
10/06/15 05:16 PM
10/06/15 05:16 PM
Northeast MA
Charger446 Offline
Charger446  Offline
Northeast MA
Im running MSD 8.5 cut to fit wires. They fit perfectly with 2" CPPA/TTI headers on my 440.
Re: Super comps and plug wires...which wires to use? [Re: BLACK71] #1927197
10/06/15 06:21 PM
10/06/15 06:21 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I run RPM heads w/angled plugs so no issues and run all of my wires UNDER the tubes against the block................
Re: Super comps and plug wires...which wires to use? [Re: Thumperdart] #1927211
10/06/15 06:48 PM
10/06/15 06:48 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
I got the morose ultra 40 big block Chevy wires with the insulated jacket and stuff ..fits perfect I just cut the numbers off and wrote on the top of the boot which plug the wire went to..
Re: Super comps and plug wires...which wires to use? [Re: earthmover] #1927383
10/06/15 11:17 PM
10/06/15 11:17 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I have Eddy heads and super comps on my car and I also use Firecore wires.
Mine are also run under the headers against the block and have 90 deg plug ends.
Re: Super comps and plug wires...which wires to use? [Re: BLACK71] #1928052
10/07/15 11:21 PM
10/07/15 11:21 PM
tulsa ok
U
upnover Offline
upnover  Offline
U
tulsa ok
i run the firecores, on my lowdeck i needed a 90 degree boot on the #8 cylinder and all others were straight with 440 source straight plug heads, with my indy heads they are angle plug and they take more 90's.
Re: Super comps and plug wires...which wires to use? [Re: upnover] #1928163
10/08/15 03:00 AM
10/08/15 03:00 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Firecore here also.Rick will make them anyway you need them!!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
