Wiindshield crank on my truck is stuck
#1926728
10/06/15 12:41 AM
10/06/15 12:41 AM
Posts: 18,575 Dreaming of the 808
AZ_A12_BEE
Dreaming of the 808
The windshield crank that cranks the windshield open and closed is stuck open, I lubricated it real good a few weeks ago. Can I access the mechanism if I remove the upper dash by removing the 8 upper screws and 6 lower screws?
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
Re: Wiindshield crank on my truck is stuck
[Re: AZ_A12_BEE]
#1926836
10/06/15 06:46 AM
10/06/15 06:46 AM
Posts: 1,513 AZ
Mike P
AZ
It's been a long time since I pulled mine, but as I recall......
Pull the 2 screws that hold the arm to the windshield frame.
Remove the handle,(fold out the crank and remove the center screw under it to remove the crank).
There should be 2 screws under the chrome bezel. When those are removed the whole assembly should drop out.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold 1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold 1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears)
[Re: RodStRace]
#1928787
10/09/15 01:07 AM
10/09/15 01:07 AM
AZ_A12_BEE
Dreaming of the 808
f What a great idea, will make one myself, thanks
37 Plymouth PU
[Re: AZ_A12_BEE]
#1929304
10/09/15 10:29 PM
10/09/15 10:29 PM
Posts: 19,485 north of coder
moparx
f What a great idea, will make one myself, thanks i second that ! i haven't been over to the hamb in a few years even tho i'm a member, but some of those guys come up with some very clever problem solvers ! thanks for sharing that tip !
[Re: moparx]
#1930603
10/12/15 01:33 AM
10/12/15 01:33 AM
AZ_A12_BEE
Dreaming of the 808
if possible, please post pics of the assembly when it is out. thanks ! Here you go
37 Plymouth PU
[Re: moparx]
#1930605
10/12/15 01:35 AM
10/12/15 01:35 AM
AZ_A12_BEE
Dreaming of the 808
M if possible, please post pics of the assembly when it is out. thanks ! All apart
37 Plymouth PU
