8 3/4 good or bad? #1926000
10/05/15 02:15 AM
10/05/15 02:15 AM
garnett kansas
rhad Offline OP
rhad  Offline OP
garnett kansas
ive got a junk trailer made from a 70 or so sweptline pickup,its been setting close to 20 yrs without being moved,whats the chances the gears are rusty from not being turned in all those years?
its a 741 case
my ladder of success is missing some rungs
Re: 8 3/4 good or bad? [Re: rhad] #1926039
10/05/15 05:37 AM
10/05/15 05:37 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
chances are they are still good if it's not humid where you are at
good luck
Re: 8 3/4 good or bad? [Re: Morty426] #1926075
10/05/15 09:54 AM
10/05/15 09:54 AM
I think you will be fine. do check the fluid level first
Re: 8 3/4 good or bad? [Re: rhad] #1926103
10/05/15 10:42 AM
10/05/15 10:42 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
should be fine unless it was open to the elements. I'd probably drain it and refill it with new gear oil.
Coming soon!!!!
Re: 8 3/4 good or bad? [Re: Mr.Yuck] #1926136
10/05/15 11:47 AM
10/05/15 11:47 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Does it really matter what condition the gears are in? Its the carrier/axle bearings that are really in play here? I would have to decide whether to run axle first time after 20? yrs to operating temp, and then immediately drain it, or do it before moving. Changing lube regardless would be a must for me.
Just dawned on me, there is no easy way to change the OEM 8.75 lube. Good luck.
Re: 8 3/4 good or bad? [Re: jcc] #1926305
10/05/15 03:42 PM
10/05/15 03:42 PM
dogdays Offline
dogdays  Offline
Shoot, I'd run it.
R.
Re: 8 3/4 good or bad? [Re: rhad] #1926378
10/05/15 05:18 PM
10/05/15 05:18 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Many years ago I was given a complete truck 8 3/4" with 3.91 SG and tires. Rather than tear it apart I decided to leave it complete until needed and parked it along side my shop. Years later I pulled it apart because I had a use for the pumpkin and I found about 1/2" of water in the bottom of the housing...enough to rot away the bottom two teeth on the ring gear.
Although completely sealed from rain, I surmise condensation was the source of the water. Use 'em or lose 'em.
Re: 8 3/4 good or bad? [Re: jcc] #1926389
10/05/15 05:38 PM
10/05/15 05:38 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
gear lube will not affect the bearings, they require packing with grease...
Re: 8 3/4 good or bad? [Re: dogdays] #1926404
10/05/15 06:01 PM
10/05/15 06:01 PM
Originally Posted By dogdays
Shoot, I'd run it.
thats what I'd do. especially since you ain't applying any torque to it. I'd check the fluid & jack it up & see if it turns free & if all good then you're good.
Re: 8 3/4 good or bad? [Re: rhad] #1926418
10/05/15 06:18 PM
10/05/15 06:18 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Use a suction pump to remove the fluid if you don't want to crack it open . The cheapo one from harbor freight works good.
Re: 8 3/4 good or bad? [Re: rhad] #1926473
10/05/15 07:26 PM
10/05/15 07:26 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
20 years sitting out back ... sure run it as is ... go for it , it won't hurt me one bit fan
Re: 8 3/4 good or bad? [Re: rhad] #1926606
10/05/15 10:39 PM
10/05/15 10:39 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
It's a trailer. I'd not worry about it at all. You don't need the gear teeth and you won;t hear any noise.
Re: 8 3/4 good or bad? [Re: rhad] #1926713
10/06/15 12:19 AM
10/06/15 12:19 AM
The chances for rust are outstanding for any rear end sitting stationary for 20 yrs, no matter what part of the country it sits in twocents I took a 741 third member out of a 1965 A100 van in 1975 or so and it had sat in that junkyard in Hesperia, CA in the Mojave Desert for less than 20 yrs, it had rust on all the ring gear teeth above the lube line puke It did wipe right off and it wasn't pitted, I didn't buy it but someone else did and swore it was good later confused shruggy BTW, that one was 741 case with a 3.91 posi work I should have bought it realcrazy
Re: 8 3/4 good or bad? [Re: minivan] #1926715
10/06/15 12:21 AM
10/06/15 12:21 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Wheel bearings yes, but the other end of the axle shaft is supported by the differential bearings and they require gear oil.
Don't be the exception.
