'05 1500 HVAC issue
#1925683
10/04/15 05:36 PM
10/04/15 05:36 PM
Posts: 11,608 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Picked up a high mileage 2005 1500 a couple of months ago. A/C wasn't very cold. Just figured it needed a little freon and never got around to it. Now with cooler weather, we tried to get some heat the other day. Very little heat. Google around and assume a blend door issue.
I don't want to spend days fixing this. I've found a shortcut fix from HeaterTreater for fixing the doors. Anyone familiar with this deal? Any other suggestions? I'm going to get under the dash and try to verify the cause this week.
Re: '05 1500 HVAC issue
[Re: CMcAllister]
#1925745
10/04/15 08:09 PM
10/04/15 08:09 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Don't go choping up the box! Do it the right way, you can do it in a day if you are carefull and the result is a lot nicer.
[Re: HotRodDave]
#1926056
10/05/15 08:47 AM
10/05/15 08:47 AM
Posts: 8,671 Buford, GA
I_bleed_MOPAR
Buford, GA
Good airflow out the vents? My '06 had the recirc door break off and fall on top of the blower. Very little air out the vents. Only took about 20 min. to put a new door in.
Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: CMcAllister]
#1927324
10/06/15 09:52 PM
10/06/15 09:52 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Airflow is good. Mode changes fine. This is a high mileage work truck. Trying to see what my options are. Is there even a way to move the doors by hand on this? Haven't had my head under the dash yet.
