Wiring Harness Plugs
#1924868
10/03/15 01:33 PM
10/03/15 01:33 PM
Posts: 607 NY
old340dog
NY
While I was working on my Duster this morning, noticed that 2 out of 3 terminals that plug into my bulkhead on firewall have the little plastic clips broken or missing. Since these clips hold the terminal to the bulk head for a good connection.I want to replace or fix the problem before I do have a problem. Does anyone make the replacement terminals for these in the right size to fit the bulk head?Or is there another way to fix these?
old340dog
Re: Wiring Harness Plugs
[Re: old340dog]
#1924902
10/03/15 02:19 PM
10/03/15 02:19 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Look for Packard 56 terminals, that may be the type you need. TIm
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: old340dog]
#1924907
10/03/15 02:37 PM
10/03/15 02:37 PM
astjp2
Utah and Alaska
[Re: Pynzo]
#1925008
10/03/15 05:07 PM
10/03/15 05:07 PM
Posts: 607 NY
old340dog
NY
Thanks for the information. On the Megaparts.com web site I see they list a headlight terminal for my year car.Not sure if this what I need.It looks like mine. The 2 terminals have bad on my car have the wires from the harness on them. Each one plugs into the bulkhead.The snap clip on the terminals are broken or missing. Is what they call the headlight terminal the one I need or is there ones made for plugging into the bulkhead?
old340dog
[Re: old340dog]
#1925009
10/03/15 05:11 PM
10/03/15 05:11 PM
Posts: 1,386 Philadelphia PA
Pynzo
Drugs are bad
Drugs are bad
Philadelphia PA
Post some pics of what is broken. Plastic pieces are connectors, terminals are the metal spades inside them.
[Re: Pynzo]
#1925048
10/03/15 05:51 PM
10/03/15 05:51 PM
Posts: 607 NY
old340dog
NY
Hopefully attached are 2 pictures.Notice at the top of the left and center plugs. The black tabs that are suppose to hold the terminal to the block are missing. I need to replace the terminals.Is this possible and are what they call front headlight terminals on megaparts.com what I need?
old340dog
[Re: Pynzo]
#1925083
10/03/15 06:39 PM
10/03/15 06:39 PM
Posts: 607 NY
old340dog
NY
The two on the left are the ones with the broken tabs.So what do I do to keep the connectors tight to the bulkhead without them vibrating loose. Can I get replacement connectors?
old340dog
[Re: old340dog]
#1925094
10/03/15 07:07 PM
10/03/15 07:07 PM
Posts: 4,270 Morrow, OH
markz528
Morrow, OH
Bill Evans has them $10 a piece. There were also foam seals from the factory. Bill should have those also.
[Re: markz528]
#1925105
10/03/15 07:31 PM
10/03/15 07:31 PM
Posts: 607 NY
old340dog
NY
Thanks for the information and help.How do I get ahold of Bill Evans?
old340dog
[Re: old340dog]
#1926045
10/05/15 07:55 AM
10/05/15 07:55 AM
Posts: 607 NY
old340dog
NY
Does anyone know how to contact Bill Evans?
old340dog
[Re: old340dog]
#1926070
10/05/15 09:45 AM
10/05/15 09:45 AM
Pynzo
Drugs are bad
Drugs are bad
Philadelphia PA
The two on the left are the ones with the broken tabs.So what do I do to keep the connectors tight to the bulkhead without them vibrating loose. Can I get replacement connectors? What you see on the MegaParts link labeled as Terminals are the Connectors you are looking for. You need to determine which ones to get. Take a real good look at the wiring in your broken connectors. If the wiring is stiff and brittle you may want to replace the entire harness. Year One sells harnesses. http://www.evanswiring.comAnd so does Bill Evans
