shorten C body 8&3/4 axles to fit A body housing ? #1924093
10/02/15 01:14 PM
10/02/15 01:14 PM
RapidRobert Offline OP
Is this doable? there are several lengths of C body axles listed in the archives. Want to send a pair in to Moser & dont know yet what lengths the ones in question are. thank you for your time.
Re: shorten C body 8&3/4 axles to fit A body housing ? [Re: RapidRobert] #1924096
10/02/15 01:20 PM
10/02/15 01:20 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I looked into doing the same thing. I was given a free C-body 8 3/4.(mid 60's I think) The axles are basically E-body length. They taper down right at the A-body length so they won't work. My plan is to have the housing shortened and buy Dr Diff axles. Maybe different years would have an axle that doesn't taper down.
All E-body 29 31/32"
65-69 C-body 30"
Re: shorten C body 8&3/4 axles to fit A body housing ? [Re: RapidRobert] #1924116
10/02/15 01:38 PM
10/02/15 01:38 PM
crlush Offline
crlush  Offline
I had a set cut down from a c-body but can't remember what model/year, but they had to weld about 1/2" on the end becsuse it tapered down and respline, they worked good till i started running slicks then they started to twist the spline like a candy cane and ended up just buying moser axles, so in the long run it wasnt worth it.
Re: shorten C body 8&3/4 axles to fit A body housing ? [Re: crlush] #1924127
10/02/15 01:56 PM
10/02/15 01:56 PM
dogdays Offline
dogdays  Offline
The brake configuration on A-bodies is different from the others, I believe it sticks out less, so you'd have to use brake assemblies from non-A-bodies.
This question used to get asked a lot and the answer was there are some axles that can be cut down and resplined and some that can't. Many of the axles taper too early so there isn't enough material. And I'd never recommend welding on an axle shaft.
R.
Re: shorten C body 8&3/4 axles to fit A body housing ? [Re: dogdays] #1924133
10/02/15 02:04 PM
10/02/15 02:04 PM
Alright, iirc Moser told me way back that it needs at least 28" from outside of flange to axle tip for them to be good candidates and at least 1" of spline is needed when you are done for proper engagement. sounds like I need to get em in hand & go from there. thanks guys!
Re: shorten C body 8&3/4 axles to fit A body housing ? [Re: RapidRobert] #1924155
10/02/15 02:34 PM
10/02/15 02:34 PM
Seminole County FL to Plymouth...
Barry70GTX Offline
Barry70GTX  Offline
I've had Moser cut down several sets of 70-74 C and truck axles over the years.
NMCA NSS 67 Coronet
Re: shorten C body 8&3/4 axles to fit A body housing ? [Re: RapidRobert] #1924346
10/02/15 06:41 PM
10/02/15 06:41 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Robert...why not just buy the correct axles from Dr. Diff?
...FAFO...
Re: shorten C body 8&3/4 axles to fit A body housing ? [Re: RapidRobert] #1924352
10/02/15 06:49 PM
10/02/15 06:49 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
On most axle shafts the first 3" of the spline end is necked down so only the C-body and truck 31"+ shafts are suitable to be shortened to 28" for the A-body. Even if the shaft is long enough there's not always enough meat for shortening/resplining because of shaft irregularities.
Less hassle to buy new.
Re: shorten C body 8&3/4 axles to fit A body housing ? [Re: John_Kunkel] #1924398
10/02/15 07:49 PM
10/02/15 07:49 PM
More good info. I'll measure em
Re: shorten C body 8&3/4 axles to fit A body housing ? [Re: RapidRobert] #1924579
10/02/15 11:50 PM
10/02/15 11:50 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I have a set Mosr did. I used E body. Moser told me truck, E and late C body were the only ones they would cut.
Moser can do them for A body brakes, but then you need your drums redrilled too.
Re: shorten C body 8&3/4 axles to fit A body housing ? [Re: RapidRobert] #1924733
10/03/15 03:46 AM
10/03/15 03:46 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
When I had a set done I called Moser and they told me what to measure (it's been too long to remember what that number is). The axles that I used came from 69-70 C-body wagons...
Re: shorten C body 8&3/4 axles to fit A body housing ? [Re: Jim_Lusk] #1924743
10/03/15 04:04 AM
10/03/15 04:04 AM
iirc they said hook your tape over the flange & out to the end they need (at least) 28" before it starts to neckdown
Re: shorten C body 8&3/4 axles to fit A body housing ? [Re: RapidRobert] #1924872
10/03/15 01:44 PM
10/03/15 01:44 PM
Virginia
BSharp Offline
BSharp  Offline
Virginia
From Tom Condran's "Performance Handling for Classic Mopars":
Re: shorten C body 8&3/4 axles to fit A body housing ? [Re: skicker] #1926173
10/05/15 12:28 PM
10/05/15 12:28 PM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
Definitely agree, it's a no brainier for me... Why spend the money on a set of old stock axles when you can order a brand new set from Dr. Diff that are stronger than factory axles, not to mention NEW, and have green bearings.
Re: shorten C body 8&3/4 axles to fit A body housing ? [Re: RapidRobert] #1926216
10/05/15 01:47 PM
10/05/15 01:47 PM
AndyF Online content
AndyF  Online Content
Old trick from back in the day before people were making new axles. These days I wouldn't bother. Kind of like welding up a factory crank to build a stroker motor. We did it 30 years ago but I wouldn't do it today.
Re: shorten C body 8&3/4 axles to fit A body housing ? [Re: 340_Dart] #1926295
10/05/15 03:30 PM
10/05/15 03:30 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
Curious, Are Dr. Diffs axles able to use Standard tapered bearings too?
Re: shorten C body 8&3/4 axles to fit A body housing ? [Re: Jwilli500] #1926313
10/05/15 03:48 PM
10/05/15 03:48 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I can agree with most all of that, but if I were doing it I would go for a hybrid and opt for the Phord "Torino" big wheel bearings, Phord housing ends and use the racing Phord 11" brake drum kits for the rear that are brand new complete. That way you get better wheel bearings that are prepacked and sealed, new rear brakes that are probably a lot more than you need with a parking brake that is easy to adapt to your existing cables and a bolt pattern that will fit the BBP wheels you will want. We can continue the 8.75" discussion vs. Phord 9" vs Dana 60 if you must, but at least we now have the axle issue settled. JMHO.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: shorten C body 8&3/4 axles to fit A body housing ? [Re: RapidRobert] #1926610
10/05/15 10:44 PM
10/05/15 10:44 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
My axles are compatible with Mopar Green ball bearings, Mopar Set 7 tapered roller bearings and Ford Set 20 tapered roller bearings, all of which I stock.
Re: shorten C body 8&3/4 axles to fit A body housing ? [Re: DoctorDiff] #1926717
10/06/15 12:23 AM
10/06/15 12:23 AM
Armada MICH.
DUSTER_340 Offline
DUSTER_340  Offline
Armada MICH.
So with a C body axle and 11 x 2-1/2 inch brakes, what width do you need to have the housing cut to, in an A body ,to place the wheel in a stock location? Assuming 15" x 6" 3-3/4" back spacing ,4.5" bolt circle steel wheels.
Re: shorten C body 8&3/4 axles to fit A body housing ? [Re: DUSTER_340] #1926882
10/06/15 10:17 AM
10/06/15 10:17 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Using B-C Body and later A body brake drums and backing plate have no bearing on width. (maybe a small amount being only the thickness of the drum at the axle flange) The axle flange dimension is the dimension you need from left to right.
Its not 1985 any more...there are better options out there than reusing 40-50 year old parts... twocents
...FAFO...
