Page 1 of 3 1 2 3
318 Duster won't keep timing #1924401
10/02/15 07:52 PM
10/02/15 07:52 PM
SoCal
RustyDuster Offline OP
SoCal
I have a 1973 Duster with a 1968 318 engine. Here's my problem:
I set the timing according to specifications. I drive for a while then later when I try to restart the car, it won't start again until I have reset the timing. Once it is reset, it starts right up.
-I recently (as in a couple years ago) changed the timing chain
-The air gap for the distributor is in spec
-The engine block is a 1968 and is set for 1968 specs (this caused some frustration earlier)
-carburetor is new
Any additional suggestions from you guys on where to look for the source of this problem?
Re: 318 Duster won't keep timing [Re: RustyDuster] #1924421
10/02/15 08:15 PM
10/02/15 08:15 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
is the distrib clamp bolt tight? I cant think of anything besides this that would let the timing change.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: 318 Duster won't keep timing [Re: HemiRick] #1924428
10/02/15 08:37 PM
10/02/15 08:37 PM
SoCal
SoCal
I just checked it to be sure and it's tight..
Re: 318 Duster won't keep timing [Re: RustyDuster] #1924489
10/02/15 10:02 PM
10/02/15 10:02 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Had an aspen w this problem. Several things I found- dist bushing had play, timing chain slack, slipping dampner, and worn cam. Every single time I drove it the timing had to be reset, so I got pissed and yanked the motor and replaced w refreshed one so I could drive car and diagnose engine out of the vehicle....got a spare laying around?
Re: 318 Duster won't keep timing [Re: RustyDuster] #1924492
10/02/15 10:06 PM
10/02/15 10:06 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Also, every time I set the timing, it had to be set ahead, because once you tightened the clamp on the dist down, the timing mark would move. Actually watched it happen while friend tightened bolt.
Re: 318 Duster won't keep timing [Re: RustyDuster] #1924517
10/02/15 10:37 PM
10/02/15 10:37 PM
Electronic ign conversion or are you meanin point gap?. If point gap next time (actually with either one) BEFORE you crank it see what the gap is & you might pull (& GROUND) the coil wire & crank it & see what the timing light shows for initial. Any possibiblity it ain't a timing issue & something else is causing this (heat soak etc). I would go over the dist innards from head to toe tho.
Re: 318 Duster won't keep timing [Re: RustyDuster] #1925301
10/04/15 12:37 AM
10/04/15 12:37 AM
Ohio
shorthorse Offline
shorthorse  Offline
Ohio
Is there any consistency in the amount of timing that is off? Is it retarded or advanced? Do you have to reset the timing no matter if the car is cold or still hot/warm? Last, have you ever checked the timing before you shut it off?
Re: 318 Duster won't keep timing [Re: shorthorse] #1925325
10/04/15 01:04 AM
10/04/15 01:04 AM
SoCal
SoCal
Not that I can detect
The factory specification for 1968 is 10 degrees advanced. When the timing shifts after operation, it appears to be retarded. Because I have to advance it to put it back to spec.
The timing only shifts after it has been in operation, so warm.
I haven't tried that yet.
Re: 318 Duster won't keep timing [Re: RapidRobert] #1925328
10/04/15 01:05 AM
10/04/15 01:05 AM
SoCal
SoCal
The car is electronic ignition. I've changed the cap and ordered a new distributor, hopefully this will help.
Re: 318 Duster won't keep timing [Re: RustyDuster] #1925431
10/04/15 09:50 AM
10/04/15 09:50 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Vacuum disconnected when setting timing?
Angry white pureblood male
Re: 318 Duster won't keep timing [Re: RustyDuster] #1925592
10/04/15 02:34 PM
10/04/15 02:34 PM
Pa. U.S.A.
moparborn Offline
moparborn  Offline
Pa. U.S.A.
Check the gear on the distributor,is it tight?
Re: 318 Duster won't keep timing [Re: RustyDuster] #1925606
10/04/15 02:49 PM
10/04/15 02:49 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
gear on the distributor? There is no gear on a small block distributor, nor a big block for that matter. There is one on the slant 6 though.
If the gear on the intermediate shaft was loose, which is where the gear that drives the distributor is actually located, then the oil pump would be failing too. Has the OP seen oil pressure issues?
Don't be the exception.
Re: 318 Duster won't keep timing [Re: RustyDuster] #1925615
10/04/15 02:59 PM
10/04/15 02:59 PM
this deal ain't makin any sense, we're missing something here. I cant wait till we get to the bottom of whats going on
Re: 318 Duster won't keep timing [Re: Supercuda] #1925622
10/04/15 03:07 PM
10/04/15 03:07 PM
Pa. U.S.A.
moparborn Offline
moparborn  Offline
Pa. U.S.A.
I stand corrected.
I should have stated distributor drive gear.
"it appears to be retarded. Because I have to advance it to put it back to spec.
This is with a timing light?How does it run when you start it with corrected timing and how long?
Distributor bolt is tight but is the distributor itself tight?
Re: 318 Duster won't keep timing [Re: RustyDuster] #1925646
10/04/15 04:09 PM
10/04/15 04:09 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Good point, bolt could be bottoming out before the clamp tightens down on the distributor.
Other thing that's been floating in my head, and it's way out there, is a broken distributor shaft inside the housing.
Re: 318 Duster won't keep timing [Re: RustyDuster] #1925681
10/04/15 05:16 PM
10/04/15 05:16 PM
Pa. U.S.A.
moparborn Offline
moparborn  Offline
Pa. U.S.A.
If the shaft was broken I would bet it would be a whole lot worse,under acceleration or high rpm the timing would probably slip beyond runable.
Re: 318 Duster won't keep timing [Re: RustyDuster] #1925707
10/04/15 06:33 PM
10/04/15 06:33 PM
Spring City , Pa.
SIKPUP Offline
SIKPUP  Offline
Spring City , Pa.
Does your timing chain have all steel gears ? or the plastic coated ones ?
Re: 318 Duster won't keep timing [Re: RustyDuster] #1925726
10/04/15 07:16 PM
10/04/15 07:16 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
I've seen this happen once on a car where the intermediate shaft gear and the gear teeth on the cam were almost totally worn away.
Pull the distributor and look at the tang. Also pull the intermediate shaft and check for wear.
Re: 318 Duster won't keep timing [Re: ruderunner] #1925770
10/04/15 08:59 PM
10/04/15 08:59 PM
SoCal
SoCal
The vacuum is blocked when setting timing, so yes.
Re: 318 Duster won't keep timing [Re: moparborn] #1925771
10/04/15 09:00 PM
10/04/15 09:00 PM
SoCal
SoCal
It is tight.
Page 1 of 3 1 2 3
