Trans Question. #1924309
10/02/15 05:49 PM
10/02/15 05:49 PM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
Hi All.
When I shift from 2nd to 3rd the car almost stops. Don't notice it at speed but when cruising at light throttle, back to the pit it almost throws me into the dash pad blush
I rebuilt the trans at the begining of the season, been doing it all the time but i had other stuff to sort out.
What have I done wrong?
TIA up
Re: Trans Question. [Re: Tig] #1924339
10/02/15 06:35 PM
10/02/15 06:35 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
You're experiencing severe overlap wherein the front clutch applies before the kickdown band releases...in essence in two gears at the same time.
Two ways to reduce the overlap are to delay the clutch engagement by using more return springs in the clutch drum or restrict the fluid flow to the clutch with an orifice restrictor in the case.
Re: Trans Question. [Re: Tig] #1924354
10/02/15 06:51 PM
10/02/15 06:51 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I heard if the band adjustment was to tight it would cause something like this. Am I off base?
Re: Trans Question. [Re: Tig] #1924381
10/02/15 07:24 PM
10/02/15 07:24 PM
New York
polyspheric Offline
polyspheric  Offline
New York
TransGo claims their valve body mods greatly reduce this.
Boffin Emeritus
Re: Trans Question. [Re: Tig] #1924389
10/02/15 07:33 PM
10/02/15 07:33 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I have fine tuned this by adjusting the spring load on the servo. Getting thrown into the dash is pretty severe though and may need more than fine tuning.
Re: Trans Question. [Re: Tig] #1924414
10/02/15 08:06 PM
10/02/15 08:06 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: Trans Question. [Re: polyspheric] #1924480
10/02/15 09:50 PM
10/02/15 09:50 PM
Montreal Quebec
STROKIE Offline
STROKIE  Offline
Montreal Quebec
I install TF-2 and iagree
Re: Trans Question. [Re: Tig] #1924726
10/03/15 03:31 AM
10/03/15 03:31 AM
Who, brand and part number, valve body is it? I've seen shifter cable adjustments make bad things happen on more than one Mopar with both reverse manual shift valve bodys and some standard valve body with shift kits in them scope. Most of those where bad on the 1st to 2nd gear shifts though confused I like to have my cables adjusted so the male pin on the cable end drops into the hole on the shifter arm hooked to the valve body in all three forward gears as well drops in in nuetral also, no forcing it tsk scope
Re: Trans Question. [Re: Tig] #1924757
10/03/15 07:22 AM
10/03/15 07:22 AM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
Hi All.
Thanks for the replies so far. Here's a little more info. Problem seems worse when the trans is hot.
The front drum is a CRT steel that fits 6 thins. I recall checking the clutch pack and the clearence being on the tight side of the limit with 6 plates. Billet servo with all the springs. Lever is a 4.2, we've tried backing off the band but it was still the same. The valve body is a Griner RMVB LBA.
Re: Trans Question. [Re: Tig] #1924945
10/03/15 03:34 PM
10/03/15 03:34 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I am going to stick with this topic because I have a TCS billet front drum that I was planning on having installed in the race 727 that was built by local guru Pat Blais. He told me earlier that there can be clearance issues in the front clutch pack when you use the billet front drum. Aside from that, why are you going through the gears on the way back from a run? Why not just leave it in high or 2nd and motor gently back, you race on the track, not the return road.
From the description of your car, I thought it was a race only ride and then I realized you were street driving it and seeing the problem under part throttle on the street, not surprised at that now. Good luck taming it down.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Trans Question. [Re: Tig] #1925115
10/03/15 07:48 PM
10/03/15 07:48 PM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
It didn't do this before I rebuilt the box for this season. I'll be pulling it apart over winter just need some pointers on what to look for.
Re: Trans Question. [Re: Tig] #1925319
10/04/15 12:59 AM
10/04/15 12:59 AM
I let a local trans shop set a bracket 727 trans up for me one time, they added additional plates to both drums thinking that was the hot set up for a "race" motor, it isn't down That rascal would try and creep in nuetral when revved up down The shop used a Trans Go shift kit also, it was like your deal on jackstands, I could see the rear wheels almost stop on the 2 to 3 shift with someone in the car revving it up and shifting it on jack stands shock
Re: Trans Question. [Re: Tig] #1925370
10/04/15 02:00 AM
10/04/15 02:00 AM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
Yep, it will also creep in neutral too.
Re: Trans Question. [Re: Tig] #1925502
10/04/15 12:03 PM
10/04/15 12:03 PM
WA
JD Dart Offline
JD Dart  Offline
WA
You will need more clearance in the front drum 6 clutches will crab before the band is released open up the clearance and maybe put a stiffer spring on the band.
Re: Trans Question. [Re: Tig] #1925649
10/04/15 04:11 PM
10/04/15 04:11 PM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
That's got me thinking, I've rebuilt it the way it was before, same clutch pack clearance and we never had that overlap issue. I'm wondering if the servo is sticking or not releasing correctly for some reason.
So for 3rd gear we have front band released and front clutch pack engaged?
Re: Trans Question. [Re: Tig] #1926031
10/05/15 04:28 AM
10/05/15 04:28 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
So for 3rd gear we have front band released and front clutch pack engaged? Yes
You haven't mentioned 1-2 shift quality. Reason I do is - if the springs in the front servo are too soft, they create an excessively firm 1-2 shift and an overlap on the 2-3. Slightly stiffer front servo springs can slightly soften the 1-2 and get the band released a little faster, which cleans up the 2-3 shift.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Trans Question. [Re: Tig] #1926113
10/05/15 10:56 AM
10/05/15 10:56 AM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
1st to 2nd shift is barely noticeable at light load. Guessing this puts the blame on the clutch pack.
Re: Trans Question. [Re: Tig] #1926296
10/05/15 03:31 PM
10/05/15 03:31 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
No clutch pack involved in the 1-2 upshift but a faulty front servo could cause both the soft 1-2 shift and the balky 2-3 shift.
Re: Trans Question. [Re: Tig] #1926325
10/05/15 04:07 PM
10/05/15 04:07 PM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
RPM trace shows the same RPM drop for both shifts (aprox 1000rpm), and roughly the same time (drop and recovery) of 0.3 - 0.4 seconds. But this is obviously under full throttle. The shift is more triangular than sawtooth. Is the shift time normal?
Can you air check the servo in question?
Thanks up
Re: Trans Question. [Re: Tig] #1926383
10/05/15 05:29 PM
10/05/15 05:29 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
It's easy to air check the front servo apply because the port in the case is round but the servo release port in the case is odd-shaped so it take a little creativity to introduce air into it.
