Ball joint dimensions?
#192372
01/13/09 08:28 PM
01/13/09 08:28 PM
Posts: 20,217 Park Forest, IL
slantzilla
Park Forest, IL
Is there a chart anywhere that lists the dimensions of ball joint housings? We are fabbing up some tubular a-arms for my Daytona and need the OD of the housing to see if I can get a sleeve that will work instead of cutting up the stock a-arms. Thanks!
Re: Ball joint dimensions?
[Re: slantzilla]
#192377
01/13/09 09:35 PM
01/13/09 09:35 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
Booooo...
Well, idea #2.
Go to Napa,Autozone,etc and get them to pull a ball joint for your car, and measure it with a caliper on the spot
I have a pair on the way from Rockauto. Vatozone here didn't stock them.
Dang, my ideas just don't do much of anything...
Next thing you know you'll want to go putting one of those funny slanty engines in the car
[Re: slantzilla]
#192379
01/13/09 09:39 PM
01/13/09 09:39 PM
OzHemi
Garden Grove, CA
Yep, that's the plan.
I do have a 340 for backup if I don't like the results though.
