Re: 70 440 ebody a/c belt shakes
[Re: Jupiter331]
#1923621
10/01/15 07:20 PM
10/01/15 07:20 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Them idler puppies aren't properly trained. Some newspaper will help that. Roll it up tight and smack it a good one when it acts up, it'll learn.
In all seriousness, belts come in a couple of widths, wrong width, usually too narrow, won't work right, it doesn't grip properly. It the belts a bit too long it won't tighten up right. If it's the cheapest belt at the Zone, it's probably crap off the shelf.
You don't give a make/model/engine/etc info so it's hard to say but surf Rockauto and see if the numbers there match your belt.
[Re: Jupiter331]
#1923951
10/02/15 04:39 AM
10/02/15 04:39 AM
RapidRobert
bad belt. worn side grooves in pulley. missing idler pulley. improper alignment (maybe). too long of belt (something not positioned right as in mismatched parts-pulleys too far away from each other. Just throwin some potentials out there
[Re: Jupiter331]
#1924265
10/02/15 04:37 PM
10/02/15 04:37 PM
Supercuda
About to go away
About to go away
up yours
Gates shows the belt to be 13/32" wide, Dayco shows it to be 15/32" wide.
I'd go with Dayco myself.
[Re: Jupiter331]
#1924403
10/02/15 07:57 PM
10/02/15 07:57 PM
Posts: 25,988 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Even with brand new matched pair belts, the belt wobble is normal....the belts simply span too much length without support. In the later years the factory added an idler pulley to bear on the top of the belts between the compressor and the alternator to lessen the wobble.
