Oil press sender #192328
01/13/09 06:07 PM
01/13/09 06:07 PM
Ohio
LS-300 Offline OP
LS-300  Offline OP
Ohio
I have an issue with the oil pressure sending unit in my 92 Dakota w/318 Magnum. Truck has a gauge in the dash and it would seem that the switch or the gauge is bad. I was wondering if I could ohm out the switch or add a potentiometer across the plug and use it to get the gauge to work or verify that it is the problem. The switch is the 2 plug slim type as opposed to the single wire fat one. I've looked for specs for both units, switch and gauge, but have had no luck. HELP!
1979 Chrysler 300 1968 Barracuda project
Re: Oil press sender [Re: LS-300] #192329
01/14/09 10:34 AM
01/14/09 10:34 AM
Ohio
LS-300 Offline OP
LS-300  Offline OP
Ohio
What has nobody ever checked these out? Or do you just repace things in hopes of correcting the problem? I was wondering what kind of restance readings I should get and if I use a pot across the plug can I mimick the switch?
Re: Oil press sender [Re: LS-300] #192330
01/14/09 11:31 AM
01/14/09 11:31 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Better off just buying a new sender or grabbing one from the junkyard. These things die from time to time.
Re: Oil press sender [Re: DaytonaTurbo] #192331
01/14/09 07:12 PM
01/14/09 07:12 PM
Tulsa, Oklahoma
Wagonmaster Offline
Wagonmaster  Offline
Tulsa, Oklahoma
Has the gauge worked before with the switch that is in it? Most gauges require the "bell" switch.
Re: Oil press sender [Re: Wagonmaster] #192332
01/15/09 11:55 AM
01/15/09 11:55 AM
Ohio
LS-300 Offline OP
LS-300  Offline OP
Ohio
The switch in there is the original equipment one. According to the previous owner the gauge quit working about 8 years ago. I also noted that the temp gauge was acting funny as well. I am looking for comformation that the switch is bad or is it actually the gauge? I'm cheap and refuse to just replace parts in hopes of fixing it.
