Page 12 of 13 1 2 10 11 12 13
Re: 37 Plymouth PU Ressurection. [Re: RodStRace] #1499230
12/03/14 04:07 PM
12/03/14 04:07 PM
moparx Offline
moparx  Offline
Got these ones out, I'm going to replace all the screws with new Philips style screws
I would highly recommend torx head, better grip with the driver, both in and out.
YES, or good quality Allens.
Phillips are worse than flat!
absolutely ! also, make sure you don't get the replacements a couple or so too long of thread length, as this will cause multiple problems with the glass/framework install.
Re: 37 Plymouth PU Ressurection. [Re: 36dodge] #1499231
12/22/14 01:50 AM
12/22/14 01:50 AM
Jacksonville Florida
elitecustombody Offline
Good to see progress...moving right along
Wanna come work on mine
Got two of them 36 & 37 Dodges
Anyone have a spare set of rear fenders for 36-38 Dodge,37-38 Plymouth truck?
Re: 37 Plymouth PU Ressurection. [Re: elitecustombody] #1499232
12/22/14 04:56 AM
12/22/14 04:56 AM
NH
3
36dodge Offline
36dodge  Offline
NH
Stefan.....I thought you sold yours?
Re: 37 Plymouth PU Ressurection. [Re: 36dodge] #1499233
12/24/14 01:27 AM
12/24/14 01:27 AM
Michael, I sold the 36 Dodge and 37 PT50, still have complete 38 and partial late 35 I'm gathering parts for
Re: 37 Plymouth PU Ressurection. [Re: elitecustombody] #1922214
09/30/15 12:58 AM
09/30/15 12:58 AM
Dreaming of the 808
AZ_A12_BEE Offline OP
Dreaming of the 808
Picked back up on the 37 to start driving it again. Welded up 31 holes in the lower firewall and reinstalled it
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: 37 Plymouth PU Ressurection. [Re: AZ_A12_BEE] #1922217
09/30/15 01:01 AM
09/30/15 01:01 AM
Dreaming of the 808
Dreaming of the 808
Done and reinstalled
Re: 37 Plymouth PU Ressurection. [Re: AZ_A12_BEE] #1922219
09/30/15 01:05 AM
09/30/15 01:05 AM
Dreaming of the 808
Dreaming of the 808
Made a new metal floorboard to replace the wood one, I used 3/4 square tubing and 14 guage flat steel, welded the frame then the flat plate
Re: 37 Plymouth PU Ressurection. [Re: AZ_A12_BEE] #1922220
09/30/15 01:06 AM
09/30/15 01:06 AM
Dreaming of the 808
Dreaming of the 808
Completed
Re: 37 Plymouth PU Ressurection. [Re: AZ_A12_BEE] #1922221
09/30/15 01:08 AM
09/30/15 01:08 AM
Dreaming of the 808
Dreaming of the 808
Installed
Re: 37 Plymouth PU Ressurection. [Re: AZ_A12_BEE] #1922227
09/30/15 01:10 AM
09/30/15 01:10 AM
Dreaming of the 808
Dreaming of the 808
Replaced crappy transmission support with a new one I bought from Speedway Motors
Old crappy one and new one
Re: 37 Plymouth PU Ressurection. [Re: AZ_A12_BEE] #1922229
09/30/15 01:12 AM
09/30/15 01:12 AM
Dreaming of the 808
Dreaming of the 808
Installed, just need to bolt it down and weld it up
Re: 37 Plymouth PU Ressurection. [Re: AZ_A12_BEE] #1922230
09/30/15 01:13 AM
09/30/15 01:13 AM
Dreaming of the 808
Dreaming of the 808
More
Re: 37 Plymouth PU Ressurection. [Re: AZ_A12_BEE] #1922897
09/30/15 10:59 PM
09/30/15 10:59 PM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
So if you weld those flanges to the crossmember, will you still be able to remove it? How will it drop down with the bottom flanges on the frame rails? Curious minds want to know. Gene
Re: 37 Plymouth PU Ressurection. [Re: poorboy] #1922996
10/01/15 01:22 AM
10/01/15 01:22 AM
Dreaming of the 808
Dreaming of the 808
f
Gene, cross member is only bolted to the frame rails, plus frame widens towards the rear so it can slide back to remove trans if needed
Re: 37 Plymouth PU Ressurection. [Re: AZ_A12_BEE] #1923475
10/01/15 04:58 PM
10/01/15 04:58 PM
Freeport IL USA
Freeport IL USA
OK! Thanks. So much of the "newer" stuff has parallel frame rails, and I forget the older ones got wider at the center. It kind of goes with being under too many of these things over the years. Gene
Re: 37 Plymouth PU Ressurection. [Re: AZ_A12_BEE] #1923519
10/01/15 05:38 PM
10/01/15 05:38 PM
New Mexico USA
jingro Offline
jingro  Offline
New Mexico USA
Which transmission mount did you order from Speedway Motors?
Re: 37 Plymouth PU Ressurection. [Re: AZ_A12_BEE] #1923532
10/01/15 05:46 PM
10/01/15 05:46 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Might want to just tack it together and verify it's removable before you commit. Better to verify that it works now than assume it does and find out later it don't.
Don't be the exception.
Re: 37 Plymouth PU Ressurection. [Re: AZ_A12_BEE] #1923720
10/01/15 09:19 PM
10/01/15 09:19 PM
Lehigh Acres, Florida
rickstershemi Offline
Looking really good....can't wait to see it done....Nice work !!!!!
Rickster
Re: 37 Plymouth PU Ressurection. [Re: AZ_A12_BEE] #1923893
10/02/15 01:18 AM
10/02/15 01:18 AM
Dreaming of the 808
Dreaming of the 808
Got my seat back and installed
Re: 37 Plymouth PU Ressurection. [Re: elitecustombody] #1923895
10/02/15 01:24 AM
10/02/15 01:24 AM
Dreaming of the 808
Dreaming of the 808
New gas pedal ready to install
