Fuel pump/fuel line routing question #1922849
09/30/15 10:17 PM
09/30/15 10:17 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
70 RR. 383. Decided to go with 5/16 lines with return and vapor sep. Not sure what was ordered wrong. My suspect is fuel pump..but something does not line up...???
[/URL]
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: Fuel pump/fuel line routing question [Re: JMCFAN] #1923020
10/01/15 02:17 AM
10/01/15 02:17 AM
is there a 90 deg male/female inverted flare fitting available that would shift the hose over to be under the VS nipple?
Re: Fuel pump/fuel line routing question [Re: JMCFAN] #1923131
10/01/15 11:05 AM
10/01/15 11:05 AM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Not sure but it would not be correct....Does anyone have a pic of a correct setup so I can see what I am missing..?
Re: Fuel pump/fuel line routing question [Re: JMCFAN] #1923160
10/01/15 11:20 AM
10/01/15 11:20 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Here's what mine looked like, not sure if it is the right deal?
I bent my line a little to make it line up. But I am not sure I am using the right pump, other than it has been on the car for 10 years working great.
Re: Fuel pump/fuel line routing question [Re: JMCFAN] #1923206
10/01/15 12:06 PM
10/01/15 12:06 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
looks like the pump to VS line I have is incorrect....
Re: Fuel pump/fuel line routing question [Re: JMCFAN] #1923225
10/01/15 12:34 PM
10/01/15 12:34 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Look:
Re: Fuel pump/fuel line routing question [Re: RJS] #1923441
10/01/15 04:19 PM
10/01/15 04:19 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Thanks for the pics. My problem appears to be that I went with 3/8 line and return with VS which is not correct. I can order the correct pump to VS line..does anyone have pic of VS to carb routing.. Holley carb.. mad
