325s on 10" #192264
01/13/09 03:14 PM
01/13/09 03:14 PM
Charleston
sixpackgut Offline OP
Drag Week Mod Champion
Charleston
ya think a 10" wheel is to small for 325's??
i have 315s on a 10 but the tire is alot taller. thinking about goin to 325 for a little more gear
Re: 325s on 10" [Re: sixpackgut] #192265
01/13/09 03:30 PM
01/13/09 03:30 PM
South Carolina
a408swinger Offline
mopar addict
a408swinger  Offline
mopar addict
South Carolina
I run 325's on a 10" wheel right now and they work out perfect. I believe thats what M/T recommends anyway. I run them on my Scamp and cut low 1.4's on motor and low 1.3's on nitrous in a 3350 lb Scamp with a 418" smallblock.
Re: 325s on 10" [Re: a408swinger] #192266
01/13/09 04:52 PM
01/13/09 04:52 PM
organ
maximum entropy Offline
organ
same here.
Re: 325s on 10" [Re: maximum entropy] #192267
01/13/09 05:01 PM
01/13/09 05:01 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
We have the 325s on a 10" wheel and have been a 1.20 flat.
Monte
Re: 325s on 10" [Re: Monte_Smith] #192268
01/13/09 05:14 PM
01/13/09 05:14 PM
Charleston
Charleston
ok cool
Re: 325s on 10" [Re: Monte_Smith] #192269
01/13/09 05:30 PM
01/13/09 05:30 PM
La Vernia, Texas
Pat7272 Offline
Pat7272  Offline
La Vernia, Texas
Monte
Have y'all gone quicker on a wider wheel, or does 10" work just as good as 12" (or maybe 14")?
Re: 325s on 10" [Re: Pat7272] #192270
01/13/09 05:35 PM
01/13/09 05:35 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Never tried a wider wheel. Won't really fit the car. We also run the 315s on a 10" wheel and have been in the teens with that setup. I would really like to try it on a 12", bead locked wheel, but just can't get it on there. Not saying a 10" is best, but obviously works fine.
Monte
Re: 325s on 10" [Re: Monte_Smith] #192271
01/13/09 05:38 PM
01/13/09 05:38 PM
Odessa, Tx.
cudarex Offline
cudarex  Offline
Odessa, Tx.
Monte
How much wider does the tire get going from 10" to 12" rim?
Re: 325s on 10" [Re: cudarex] #192272
01/13/09 06:16 PM
01/13/09 06:16 PM
Cab_Burge Online work
Cab_Burge  Online Work
I have two sets of the 315x60x15 M/T ET street radails mounted, one on 10 inch and the others on a 12 inch rims. The differences in section width between the two is 13 & 5/8 on the ten inch rims and 14 & 3/8 on the twelve inch rims. 3/4 inch wider on the twelves than on the ten inch rims
Re: 325s on 10" [Re: Cab_Burge] #192273
01/13/09 08:03 PM
01/13/09 08:03 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I have two sets of the 315x60x15 M/T ET street radails mounted, one on 10 inch and the other on aet of 12 inch rims. The differences in section width between the two is 13 & 5/8 on the ten inch rims and 14 & 5/8 on the twelve inch rims.
My 29.5 * 10.5 *15 Mickey slicks are 13 5/8 on a 10" wheel. I would say equivilant to a 315/60/15
Mopar Performance
Re: 325s on 10" [Re: moparniac] #192274
01/13/09 10:20 PM
01/13/09 10:20 PM
Those Mickeys look tight, did you move in the spring for that?
Re: 325s on 10" #192275
01/13/09 10:33 PM
01/13/09 10:33 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
DR diff 1" relo kit caltracs on upper hole of front spring hanger ... b body specs. well sort of
Mopar Performance
Re: 325s on 10" [Re: moparniac] #192276
01/14/09 01:03 AM
01/14/09 01:03 AM
N.E. Ohio
K
KillerBee Online content
KillerBee  Online Content
K
N.E. Ohio
If you don't mind saying what offset are the rear rims?
I'm planning on installing a B body width rear end under my 71 R/T Challenger with Dr. Diff's offset kit.
I hope to stuff a 325/50-15 drag radial under the car on a custom made set of 15x10 Torq Thrust II's with a 5.75" back spacing. I have all the parts just need the free time to test and install them.
I think I'll need to use wheel spacers on the rear.
Re: 325s on 10" [Re: KillerBee] #192277
01/14/09 06:35 AM
01/14/09 06:35 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
yes you will need to use wheelspacers wiht that much BS.
mine are 15*10 with 5"'s of backspaces... 1/8 spacer just to make sure I had 1/2 clearance off the springs ... I had my dana house made a little smaller than b body specs..
Mopar Performance
Re: 325s on 10" [Re: KillerBee] #192278
01/14/09 08:18 AM
01/14/09 08:18 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I also make a 1 1/2" offset spring hanger/shackle kit if you need more room.
Re: 325s on 10" [Re: DoctorDiff] #192279
01/14/09 08:21 AM
01/14/09 08:21 AM
Jacksonville, NC
RonP Offline
RonP  Offline
Jacksonville, NC
Plenty of good answers already Ray, but that is what I run. 325's on a 10" wheel and have been 1.29 60's on them.
Ron
