325s on 10"
#192264
01/13/09 03:14 PM
01/13/09 03:14 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
ya think a 10" wheel is to small for 325's??
i have 315s on a 10 but the tire is alot taller. thinking about goin to 325 for a little more gear
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
Re: 325s on 10"
[Re: Monte_Smith]
#192269
01/13/09 05:30 PM
01/13/09 05:30 PM
Posts: 945 La Vernia, Texas
Pat7272
La Vernia, Texas
We have the 325s on a 10" wheel and have been a 1.20 flat.
Monte
Have y'all gone quicker on a wider wheel, or does 10" work just as good as 12" (or maybe 14")?
Re: 325s on 10"
[Re: cudarex]
#192272
01/13/09 06:16 PM
01/13/09 06:16 PM
Posts: 43,223 Bend,OR USA
Cab_Burge
How much wider does the tire get going from 10" to 12" rim?
I have two sets of the 315x60x15 M/T ET street radails mounted, one on 10 inch and the others on a 12 inch rims. The differences in section width between the two is 13 & 5/8 on the ten inch rims and 14 & 3/8 on the twelve inch rims. 3/4 inch wider on the twelves than on the ten inch rims
Re: 325s on 10"
[Re: moparniac]
#192274
01/13/09 10:20 PM
01/13/09 10:20 PM
Those Mickeys look tight, did you move in the spring for that?
Re: 325s on 10"
[Re: moparniac]
#192276
01/14/09 01:03 AM
01/14/09 01:03 AM
Posts: 6,497 N.E. Ohio
KillerBee
N.E. Ohio
DR diff 1" relo kit caltracs on upper hole of front spring hanger ... b body specs. well sort of
If you don't mind saying what offset are the rear rims? I'm planning on installing a B body width rear end under my 71 R/T Challenger with Dr. Diff's offset kit. I hope to stuff a 325/50-15 drag radial under the car on a custom made set of 15x10 Torq Thrust II's with a 5.75" back spacing. I have all the parts just need the free time to test and install them. I think I'll need to use wheel spacers on the rear.
