Re: Can a 3 speed Manual hold up to a V8.. say a Stock 360
[Re: solidcam]
#192242
01/13/09 03:36 PM
01/13/09 03:36 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
one of the 3-speeds was actually standard equipment behind the 340 from 68-73. There were two 3-speed manuals in '70, an A-903 that came in 6cyl cars, and an A-230 which came in everything from 6cyl cars up to the 383. If you have the A-230, I'd say you could give that thing some serious punishment from a 360 and be fine considering it came in cars behind a 383 at one point.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
[Re: DaytonaTurbo]
#192244
01/13/09 04:34 PM
01/13/09 04:34 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
Never mind 383's, the only manual transmission available in a 413MW car was a 3spd IIRC.
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: DPelletier]
#192247
01/13/09 06:04 PM
01/13/09 06:04 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Right, just don't power shift one of those too often, they are known to go boom! Then along comes the 5K replacement bill
[Re: ScottSmith_Harms]
#192248
01/13/09 06:39 PM
01/13/09 06:39 PM
Posts: 6,680 Va. Beach, Va
69superbee383
Va. Beach, Va
70 Super Bees and Coronets that were ordered with 383's came stock with the 3 speed...all other trannys were options. My 70 has a three speed and from everything I have seen looks to be built just like the A 833 so I dont think it would have any issue holding up
77 Macho Power Wagon LWB factory 440
70 Coronet 440 N code 3 speed
[Re: RapidRobert]
#192254
01/13/09 09:57 PM
01/13/09 09:57 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
If it's an A-230 you should be OK IIRC, the A-230 gear ratios are different between the /6-318 and the 340/383 transmissions.
I ran a A230 3 speed one season in my 360 circle burner & did great. It'll have an A230 on a small machined pad on the side of the trans(I forget which side). the 1st gear is 1.49 if V8 & 1.70 if /6 one & the 2nd ratios were different but I cant remember what they were & 1st gear is synchronized also & I believe pilot dia was 4.70". EDIT might have been 4.35", its been awhile
Those are second gear ratios, but, spot on.
I looked it up /6-318 has a 1-2-3 of 3.08/1.70/1 340-383 = 2.55/1.49/1
[Re: Just Cameron]
#192257
01/13/09 11:55 PM
01/13/09 11:55 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
My 64 300 came factory with an A745 3 speed and a 413.
I wouldn;t expect the /6 three speed to hold up though.
