Trani Never saw this failure. have you? #192233
01/13/09 02:15 PM
01/13/09 02:15 PM
Long Island, New York
Tony H Offline OP
Tony H  Offline OP
'74 dart.
One day the Trani is fine, next day; Reverse is totally gone. Neutral is OK until you put it down into Drive Then Neutral stays drive.
Fluid level is fine.
I thought if neutral stayed Drive then the cause might be the linkage is lose and shifting around, only problem with that idea is that you would think the Reverse position would be Neutral and the Park position would be reverse..nope.
I never heard of such a weird Trani failure.
'75 CJ5 with all glass body and a 350 Chevy SB
'85 Chevy Stepside (the wife's)
'89 Volvo
All 100% maintained by me.
'70 valiant DD for my son
'74 Dart Swinger..Latest endeavor
http://home.lyse.net/brox/TonyPage4.html
Re: Trani Never saw this failure. have you? [Re: Tony H] #192234
01/13/09 03:33 PM
01/13/09 03:33 PM
scratchnfotraction Offline
piston in the valve body stuck
I had one stuck in low gear
would go foward in N,R,and in park it was loading the engine down like it was in a bind
then I kept trying to rev it up in park then it poped loose
pulled it back down in gear same thing stuck in low gear
when it poped loose the 2nd time it was with a bang and no more worky
time for an R&R and a new tranny
good luck with it
Re: Trani Never saw this failure. have you? [Re: Tony H] #192235
01/13/09 04:48 PM
01/13/09 04:48 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Driving forward in Neutral and binding up in Reverse is caused by a rear clutch that's not releasing. This is most often caused by a failed Belleville spring in the clutch which allows the piston to leave its bore and jam the clutch pack.
Re: Trani Never saw this failure. have you? [Re: John_Kunkel] #192236
01/13/09 04:57 PM
01/13/09 04:57 PM
it went to the scraper
what makes noise when it shift to 2nd gear
funny sound as the band aplys?
I know its on its way out also
I think I will get one built with a manual vb to get away from the throttle linkage while I am at it
but..I can now R&R my tranny in my truck in about 2 hours now
Re: Trani Never saw this failure. have you? [Re: John_Kunkel] #192237
01/13/09 05:04 PM
01/13/09 05:04 PM
BRILLIANT!
