Electric fan temp sensor switch location..? #1922269
09/30/15 03:28 AM
09/30/15 03:28 AM
alberta
Publicbottle Offline OP
alberta
Need to plumb in a thermal temp switch to turn my electric fan on & off. I have no ports left in my Mopar M1 dual plane intake ('68 340). I was thinking of welding a bung into the radiator right near where the upper hose is. Do you think that would be a reliable enough spot to run the electric fans? Thanks!
Re: Electric fan temp sensor switch location..? [Re: Publicbottle] #1922277
09/30/15 05:03 AM
09/30/15 05:03 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
That should work. Do you have an aluminum radiator? Just a guess since you mentioned welding it.
Re: Electric fan temp sensor switch location..? [Re: 451Mopar] #1922281
09/30/15 05:19 AM
09/30/15 05:19 AM
alberta
alberta
Yep, its an alumn rad from AFCO. Was gonna use a painless kit that has a switch on at 195 off at 185. The Derale kit I originally installed only lasted two summers. Had the hokey push in temp probe for the rad fins and an adjustable controller.
Re: Electric fan temp sensor switch location..? [Re: Publicbottle] #1922345
09/30/15 10:25 AM
09/30/15 10:25 AM
Andrewh Offline
Andrewh  Offline
they make a couple of other options.
one is a bung that is in the thermostat housing.
the other would be one that you put in one of your rad hoses.
finally, it wasn't that hard to tap a new hole in the intake.
Re: Electric fan temp sensor switch location..? [Re: Publicbottle] #1922426
09/30/15 12:44 PM
09/30/15 12:44 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
you're lucky you got two summers out of the Derale unit, We had 3 units fail within 3 months of install on customers cars. didn't matter which probe design we used. The probes themselves failed. We now are using spal units with no further problem.
And your upper tank location will be fine twocents
Re: Electric fan temp sensor switch location..? [Re: Andrewh] #1922501
09/30/15 02:52 PM
09/30/15 02:52 PM
alberta
alberta
Ya thats ideal! I found this one for a big block....are BB and SB not interchangeable?
https://www.meziere.com/Products/Cooling...d-BB-Mopar.aspx
Re: Electric fan temp sensor switch location..? [Re: Publicbottle] #1927403
10/06/15 11:44 PM
10/06/15 11:44 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
If it's not too late. Get an controller with an adjustable temperature switch. With the fixed set ups, your OFF setting must be higher than your thermostat temperature. If not there will be a scenario when the fan will be blowing on a radiator that is not even flowing coolant because the thermostat is closed.
