A12 starter motor date code?
#1921993
09/29/15 08:05 PM
09/29/15 08:05 PM
Posts: 3,528 Lansing, MI
70gtx440dana
Lansing, MI
I have an original starter motor with aluminum housing cast date code of 5/69 & stamped assembly date of 279 or 27th week of 69. Would this be an acceptable date code for an A12 starter. Thanks in advance.
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: A12 starter motor date code?
[Re: LYNCHROAD69.5]
#1922170
09/29/15 11:57 PM
09/29/15 11:57 PM
Posts: 305 Wisconsin
Big D A12
Wisconsin
I am guessing the part number on the starter is 2875560? The very late VIN A12 Super Bees did have this starter versus the most common 2095150.
I agree with LR 69.5, a date code of 27 9 puts you into the week of the 4th of July 1969 for the manufacture of this starter. The last week of assembly at Lynch Road for all cars appears to be the 28th week of 69.
The latest component build dates I have seen on A12 cars is in the week of 26 9, and those are EAD's. I think you have an early 1970 starter.
Hope this helps.
Seeking 1969 Lynch Road fender tags/Build Sheets/Window Stickers/VIN - Over 2300 so far thanks to you!! 2018 Demon Challenger PY4 A8 Black Hood 2017 Jeep Trail Hawk 2016 Hellcat Challenger PCP A8 1969.5 A12 Super Bee WM21 V1H F6 D21 1969 Coronet RT B5 D32 M46 N96
[Re: Big D A12]
#1922261
09/30/15 02:13 AM
09/30/15 02:13 AM
70gtx440dana
Lansing, MI
Starter part number is 2095150. Must be for a very late 69 car or even produced as a service parts piece.
[Re: 70gtx440dana]
#1922435
09/30/15 12:55 PM
09/30/15 12:55 PM
Posts: 75,089 A Banana Republic near you.
JohnRR
I have an original starter motor with aluminum housing cast date code of 5/69 & stamped assembly date of 279 or 27th week of 69. Would this be an acceptable date code for an A12 starter. Thanks in advance. What is the date stamped on the K frame ?
[Re: 70gtx440dana]
#1922437
09/30/15 12:57 PM
09/30/15 12:57 PM
70gtx440dana
Lansing, MI
Don't have an A12 car. Just trying to research the motor to see what I have.
[Re: 70RT]
#1923100
10/01/15 10:22 AM
10/01/15 10:22 AM
Big D A12
Wisconsin
Yes, I have seen "original" A12 Bee's with the 560 starter. Did I pull date codes from the starters, no, but have no reason to suspect them incorrect.
Below is the WM23M9A309948 5600 mile survivor A12 Bee. I have seen the 560 in Bee's down to the 306XXX VIN range.
The only factory reference I have seen to the 560 starter in place of the 150 starter is in the parts manual. If someone else has more information on this, please post.
[Re: 70gtx440dana]
#1923129
10/01/15 11:03 AM
10/01/15 11:03 AM
70gtx440dana
Lansing, MI
Thanks for all of the info above. Very helpful. Joe
[Re: Big D A12]
#1923414
10/01/15 03:50 PM
10/01/15 03:50 PM
JohnRR
D This would all be ASSuMEing that the dates on the starter jive with assembly dates on the car in question ...
[Re: JohnRR]
#1938445
10/25/15 07:12 PM
10/25/15 07:12 PM
Big D A12
Wisconsin
Just so we have no ARSES around here, another piece of factory literature is attached referencing the 560 starters in 1969 model year cars. TSB D69-8-10.
[Re: 62maxwgn]
#1939488
10/27/15 09:29 AM
10/27/15 09:29 AM
Big D A12
Wisconsin
Bill...
Not sure what you are asking. The 2095219 nose piece is matched with the 2095150 housing for a correct set up.
The 2875560 housing is matched with the 2875553 nose piece to be correct.
The 219 piece you show above is dated January, 1969. A12 build dates start somewhere in mid March, so this piece could be mated with a later dated 150 housing to be correct. It is a little early for the A12 cars in my opinion.
