Plumbing Cowl Mounted Fuel Pressure Gauge
#1921866
09/29/15 04:31 PM
09/29/15 04:31 PM
Posts: 5,164 CT
GTX MATT
CT
How did you guys plumb your cowl mounted fuel pressure gauge? I've heard not to use copper, and theres no way I'm going to fit a braided -4 hose between my cowl and hood and get it to close? Any hints/tips/tricks?
Re: Plumbing Cowl Mounted Fuel Pressure Gauge
[Re: GTX MATT]
#1921896
09/29/15 05:08 PM
09/29/15 05:08 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Lift off hood here and plenty of room.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: GTX MATT]
#1921926
09/29/15 05:58 PM
09/29/15 05:58 PM
Posts: 52,972 Romeo MI
MR_P_BODY
How did you guys plumb your cowl mounted fuel pressure gauge? I've heard not to use copper, and theres no way I'm going to fit a braided -4 hose between my cowl and hood and get it to close? Any hints/tips/tricks? See if you can use #3 an braided line.. IF need be you can run a short piece of copper 1/8" but attach it so it doesnt flex... then use a #3 or #4 connection point and braided line...copper line shouldnt be flexed because it will work harden and break
[Re: GTX MATT]
#1921954
09/29/15 06:46 PM
09/29/15 06:46 PM
Challenger 1
Cincinnati, Ohio
How did you guys plumb your cowl mounted fuel pressure gauge? I've heard not to use copper, and theres no way I'm going to fit a braided -4 hose between my cowl and hood and get it to close? Any hints/tips/tricks? In this "oil line" thread I posted with pictures of how I plumbed what your asking about, hopefully it'll give you an idea on how I did it without drilling any holes, at least on a challenger. Why would you use a #4? That's way too big. Link
[Re: GTX MATT]
#1921972
09/29/15 07:08 PM
09/29/15 07:08 PM
Posts: 5,164 CT
GTX MATT
CT
Alright will find something smaller, I was under the impression that 4 is what people were using. So where did the tubing go once it went through the cowl?
Thanks guys I appreciate the help
EDIT: Crap I just realized your cowl vents move with the hood. I am trying to avoid drilling more holes than I have which is why I'm trying to get something that can close in the gap between the back of the hood and cowl, I could run a hard line into an adapter like you suggested though.
Our parts stores here are junk for stuff like this, or you can buy green painted tubing and other goofy looking stuff, so I'm trying to get everything I need from Summit with another order I've got, and its a little tricky to figure out how I'm going to do it and what I need when I'm not even 100% sure whats available.
[Re: GTX MATT]
#1921985
09/29/15 07:34 PM
09/29/15 07:34 PM
MR_P_BODY
Our parts stores here are junk for stuff like this, or you can buy green painted tubing and other goofy looking stuff, so I'm trying to get everything I need from Summit with another order I've got, and its a little tricky to figure out how I'm going to do it and what I need when I'm not even 100% sure whats available. FIRST thing.. you need to check to see if the #3 line will fit your loovers... if it does then use #3 braided line all the way to your T in the fuel line... maybe someone can give you the OD measurement on the #3 line so you dont have to buy any to check... I dont think I have any right now.. but I will check.. then you would need 1/8 pipe to AN#3(most gauges are 1/8 pipe but check the gauge your using, assuming your using a carb then you want a 15# gauge... they work best in the mid range of the gauge).. then check the T you will use for that size fitting
[Re: GTX MATT]
#1922056
09/29/15 09:56 PM
09/29/15 09:56 PM
Challenger 1
Cincinnati, Ohio
Our parts stores here are junk for stuff like this, or you can buy green painted tubing and other goofy looking stuff, so I'm trying to get everything I need from Summit with another order I've got, and its a little tricky to figure out how I'm going to do it and what I need when I'm not even 100% sure whats available. If you know your dorman numbers then, you can order the stuff from Summit, dorman is a name to remember for specialty fittings/adapters. Dorman don't carry AN stuff I don't think?, but it(dorman) can get you to 1/8" pipe thread and from there you can go anywhere. IMO it would not be a good idea to squeeze a line between your hood and cowl. I think it would look crappy and be unsafe in a accident. Could pinch off the line and cause a leak, no way I would do it like that. All brake line and Dorman I buy local and AN stuff I have to order and I get it from Smokeys, not Summit. Auto parts stores can get you anything you want, you just have to ask/order it and know what you want. With this internet thing that is easier than ever. Not do with what they stock which is crap=air fresheners=
[Re: GTX MATT]
#1922249
09/30/15 01:47 AM
09/30/15 01:47 AM
Posts: 7,506 Az
Crizila
Az
How did you guys plumb your cowl mounted fuel pressure gauge? I've heard not to use copper, and theres no way I'm going to fit a braided -4 hose between my cowl and hood and get it to close? Any hints/tips/tricks? Mounted mine under the scoop using -4 line.
Fastest 300
[Re: GTX MATT]
#1922504
09/30/15 02:59 PM
09/30/15 02:59 PM
Posts: 5,164 CT
GTX MATT
CT
I'm working with a 67 B body guys. I don't think I'll pass tech if I run the lines through the cowl, right? Which is funny because there are new cars with fuel lines routed through the interior.
That 'Cuda looks like a bad mofo
