Re: Narrowing Dana 60
[Re: mechanic190]
#1921659
09/29/15 05:09 AM
09/29/15 05:09 AM
Posts: 43,286 Bend,OR USA
Cab_Burge
I would do the reverse of starting with a clean sheet, measure the width of the stock inner wheel wells to the leaf spring outer edge and the see what width wheel you can fit in there, remember the tires will be at least 1 to 3 inches wider in the section width than the wheel widths are If those 15 inch wide wheels won't fit in with the stock leaf springs in there present location they won't fit with wheel tubs later Plan and measure many times before starting Good luck, take it one step at a time
[Re: mechanic190]
#1921708
09/29/15 11:15 AM
09/29/15 11:15 AM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
You may want to consider allowing for aluminum hat disc brakes down the road at some point. The rotors on my Wilwoods are at least 1/2 inch thick or more and 3/8 thicker than the steel drum mounting area. If the wheels you want to run are not too thick at the center you can run spacers for the time being. I have run 1/2 inch spacers for many years, just be sure and stay on top of torqueing the wheels regularly. ESPECIALLY if there are washers that go over the studs. They can deform and lose clamping load. I finally went to 5/8 studs for piece of mind. Allow at least 3/4 inch clearance on both sides of the tire.
[Re: mechanic190]
#1921828
09/29/15 03:11 PM
09/29/15 03:11 PM
Posts: 11,683 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Buy, borrow or bum the correct wheels and tires you will using. Don't have to be new. I recommend using the deepest (smallest backspace) wheels you can get. Get everything out from under the truck. Mock the wheels/tires where you want them under the truck. Measure inside to inside on the mounting surface of the wheels. Start subtracting, rotor or drum thickness, axle stickout, housing end, etc. Also, make sure of where the driveline centerline is in relation to the centerline of the truck to get the pinion offset correct.
Eliminate all the guesswork. Build the rear to the wheels/tires for a perfect fit.
