Well then I guess we know different engineers, because every single one of them says (and have done the testing) that you can't get too much area on the inlet side of the pump.
Now add a taller rotor and scroll ("high volume" although I have never found out who determines what "high volume" really is) and you work the inlet side even harder.
It's simple hydraulics really.
Make the inlet as big as possible. The pressure side will take care of itself (within reason). [/quote]
Yes the larger the inlet keep the negative pressure better
but you still dont have to go crazy... I use either the standarde
or HV pumps depending on my clearances... on my 416 with lots
of extra leaks(as in EDM lifter holes and .003 clearances on
both rods and mains and PR oiling).. and I check the by-pass
on the pump to make sure where it starts to by-pass).. this
gives me 18#-20# oil pressure hot at idle.. and I do
know hydraulics.. thats what I went to school for
Remember that its the atmospheric pressure thats
pushing in the oil... the pump just creates the negative
pressure... just like the cylinder does for the engine..
and if you run mud in the pan it makes it harder to push
