Comp Max Jets? #1920737
09/27/15 05:39 PM
09/27/15 05:39 PM
off the grid
340B5 Offline OP
340B5  Offline OP
off the grid
Are they consistent with the cross-reference provided by Comp? Looking for any experience at all really.
Yeah, it's got a smallblock.
Re: Comp Max Jets? [Re: 340B5] #1920788
09/27/15 07:22 PM
09/27/15 07:22 PM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
These things are great. You'll never go back to holley's. When you change sizes,whatever is stamped on the jet is the actual hole size.
Re: Comp Max Jets? [Re: 340B5] #1920801
09/27/15 07:53 PM
09/27/15 07:53 PM
off the grid
340B5 Offline OP
340B5  Offline OP
off the grid
Good to hear. Doing a re-tune of the carb and it looked like the 83's(Holley) I put in are bigger than the 84's? It was nice to have an option between 82's and 83 jets.
Re: Comp Max Jets? [Re: 340B5] #1920924
09/27/15 11:46 PM
09/27/15 11:46 PM
Mark Whitener Offline
If you want better use BLP jets. They have a wider range of sizes than Comp and have a secondary jet with the extension as part of the jet like it shows below.
Mark Whitener
[url=www.racingfuelsystems.com[/url]
Re: Comp Max Jets? [Re: Mark Whitener] #1921004
09/28/15 02:00 AM
09/28/15 02:00 AM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Thanks Mark I didn't know BLP had their own series of main jets with extensions, looks good for the larger sizes when the jet and the extension are too close to the same size. I have used and like the Max jets
"Just a Bracket car dressed up like a streetcar"
Re: Comp Max Jets? [Re: 340B5] #1921309
09/28/15 05:28 PM
09/28/15 05:28 PM
AndyF Offline
AndyF  Offline
I use MaxJets in my 4150 carbs but I usually need the BLP jets for the Dominator carbs.
It does cost some money to get set up with a complete MaxJet kit. I think I spent $200 to get 4 of each size in the "normal" range for 4150 carbs.
Re: Comp Max Jets? [Re: 340B5] #1921317
09/28/15 05:41 PM
09/28/15 05:41 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I posted this up on Mark Whitener's forum a couple(?) of years ago and figured I'd drag it back up, considering the topic.
