01 Ram-no windshield washer: pump is good #1920415
09/27/15 02:01 AM
09/27/15 02:01 AM
Back in NJ....
E
EWJ Offline OP
EWJ  Offline OP
E
Back in NJ....
The windshield washer in My 2001 Ram recently stopped working. Pulled the whole tank assembly out today to bench test it- works fine. Could not locate a fuse for the pump. Wipers themselves work perfect. What else to check at this point?
Ed
EastCoast Land Yacht Assoc.
1967 Newport Conv: 440/4 speed
1969 GTX: 440/4 speed, TX9/TX9, A34, N96
1970 Super Bee: 383/4 speed, B5/B7
1970 Coronet RT: 440/4 speed, A34, N96
1970 Coronet RT: 440/auto, A36, N96
1970 Road Runner convertible: 383/4 speed TX9/D6XW
1970 GTX: 440+6/727, A32, N96
2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed
"The early bird may get the worm, but the 2nd mouse gets the cheese".
Re: 01 Ram-no windshield washer: pump is good [Re: EWJ] #1920507
09/27/15 11:35 AM
09/27/15 11:35 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Check for bad or blocked hoses.
Re: 01 Ram-no windshield washer: pump is good [Re: stumpy] #1920509
09/27/15 11:39 AM
09/27/15 11:39 AM
Back in NJ....
E
EWJ Offline OP
EWJ  Offline OP
E
Back in NJ....
The issue is that the pump is not getting activated via the truck harness. The pump works (bench tests with a 12v battery), but there is no power to the pump when the washer is triggered from the stalk. What controls the power to the circuit? Could not locate any fuse.
Ed
Re: 01 Ram-no windshield washer: pump is good [Re: EWJ] #1920729
09/27/15 05:31 PM
09/27/15 05:31 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
wiring= easiest would be check ground first.
