CAR BARELY STARTS #1920104
09/26/15 03:59 PM
09/26/15 03:59 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
68 Charger with mostly stock 383. Been trying to get the car running since removing from storage of 5 years. To date: changed oil, removed fuel tank, drained, cleaned and blew out all lines, new fuel filter (second) rebuilt 670 SA, new plugs, timing is correct, spark is present, fuel is present to carb and can be seen squirting out when linkage is moved. I did a compression check and compression is at all cylinders. The car wants to start and will start but only if I crank for about 10 seconds and with accelerator pedal to the floor only then will the car start and run poorly. Max rpm is 800 and running very rich. As soon as I let up on gas pedal car dies immediately. Would weak spark cause this? At the inboard side (blue and brown wire) of ballast resistor there is 10.5 volts. Car ran perfect before going into storage.
Re: CAR BARELY STARTS [Re: frank] #1920106
09/26/15 04:03 PM
09/26/15 04:03 PM
CA
crackedback Offline
crackedback  Offline
CA
Timing is correct? Per what, the book that has to take emissions into consideration?
If an engine cranks for long periods of time, requires any throttle to start and run real fat, it's usually not enough initial timing.
I run stock 340-383-440's in the 14-18 range for initial and you'll never find a book setting that will suggest that much. They don't run fat, idle clean, start at the flick of the key.
Carb could be plugged up as well. Even if the carb was plugged up, primed, the engine should fire without any throttle.
Re: CAR BARELY STARTS [Re: frank] #1920114
09/26/15 04:35 PM
09/26/15 04:35 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
The timing was good when the car went into storage and it was not adjusted. I still removed the cap and checked rotor to terminal on compression stroke at TDC. Everything was good.. I think total timing on this car was about 38-40.
Re: CAR BARELY STARTS [Re: frank] #1920125
09/26/15 04:56 PM
09/26/15 04:56 PM
vac leak
Re: CAR BARELY STARTS [Re: RapidRobert] #1920127
09/26/15 05:02 PM
09/26/15 05:02 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
I can't find anything thats not hooked up or in good condition
Re: CAR BARELY STARTS [Re: frank] #1920129
09/26/15 05:08 PM
09/26/15 05:08 PM
Andrewh Offline
Andrewh  Offline
manual choke or automatic?
did you rebuild or someone else on the carb?
I can't tell what kind, but if it is the holley type, my first time I rebuilt one, I used the wrong gasket set. it wouldn't idle.
could be the gasket under it, could be a hose you can't see the crack in.
So lets do a little diagnostic.
if you have a helper, hold the choke closed, see if it will start with your foot on the floor.
next, try pumping the gas say 5 times first, if it is warm. see if it will catch and then die when it runs out of fuel.
you can try it with 10 pumps as well. leaving the choke open.
if it starts and runs like that, I might agree, a vacuum leak somewhere to start looking for.
if it doesn't, then I would check the carb again to see if it was rebuilt correctly.
Re: CAR BARELY STARTS [Re: frank] #1920131
09/26/15 05:10 PM
09/26/15 05:10 PM
I'm thinking valley pan but you HAVE rebuilt the carb since pulling it out of storage & it is correct (no internal vac leaks from a misplaced/wrong gasket)? dist (timing) unchanged & fresh gas/plugs
Re: CAR BARELY STARTS [Re: frank] #1920146
09/26/15 05:48 PM
09/26/15 05:48 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
have you checked to make sure the carb isn't puddling?? IE: flooding due to a needle/ seat, issue shruggy
Re: CAR BARELY STARTS [Re: frank] #1920148
09/26/15 05:54 PM
09/26/15 05:54 PM
CA
crackedback Offline
crackedback  Offline
CA
Total timing has squat to do with a car at idle unless it's locked out.
Re: CAR BARELY STARTS [Re: Andrewh] #1920149
09/26/15 05:57 PM
09/26/15 05:57 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
I rebuilt the carb using a Holley rebuild kit. I matched each gasket with the replacement before installing new. Valley pan looks in good shape. I'm going to remove the carb again and look at it. How can you tell if there is an internal leak of the carb? I've tried the gas pumping previously and it did not work.
Re: CAR BARELY STARTS [Re: RapidRobert] #1920151
09/26/15 06:01 PM
09/26/15 06:01 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
I'm assuming its correct but maybe not. Fresh gas and plugs. Timing is unchanged from when the car went in storage and I checked movement of rotor. At TDC on compression its where it should be
Re: CAR BARELY STARTS [Re: frank] #1920163
09/26/15 06:29 PM
09/26/15 06:29 PM
Andrewh Offline
Andrewh  Offline
can you borrow a known good carb? or put your carb on a known good running car?
just testing parts is a good idea if you can.
Re: CAR BARELY STARTS [Re: Andrewh] #1920188
09/26/15 07:04 PM
09/26/15 07:04 PM
if the compression numbers are in the norm (~130-150 ish) then that says that the long block is OK (no blown head gasket or slipped tchain). dist housing was unmoved. its getting multiple sparks at the plug wire plug ends when cranking correct?. new gas. I keep coming back to vac leak. I would do What Andrewh said (1) do some vac leak diagnostic checks & (2) then borrow another carb. EDIT but the having to floor it goes against the vac leak idea. When it starts can you look in the carb (carefully) & see if it is dripping. Keep us posted!
Re: CAR BARELY STARTS [Re: frank] #1920195
09/26/15 07:18 PM
09/26/15 07:18 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Have you cleaned out or sprayed the distributor cap?? Could be moisture in it?? Take if off and spray with WD-40... Simple and it sure wouldn't hurt...
Re: CAR BARELY STARTS [Re: frank] #1920204
09/26/15 07:31 PM
09/26/15 07:31 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I know you said new plugs, but have you looked at them again, since this problem started? Got any pictures of them? That's the first thing I would check beside the normal stuff that you have already. It don't take long or isn't hard to foul out new plugs if things ain't right. twocents
Re: CAR BARELY STARTS [Re: frank] #1920211
09/26/15 07:38 PM
09/26/15 07:38 PM
Andrewh Offline
Andrewh  Offline
don't know how much experience you have had rebuilding either.
I know my first 3 times, the car never ran right after my rebuild attempts.
I always got one professionally rebuilt, or got a "new" carb.
so if you have done it a million times, please ignore me on that, but it really sounds like a bad carb problem, where my idle circuit was gone. had to hold the gas down to keep it running at all.
Re: CAR BARELY STARTS [Re: RapidRobert] #1920222
09/26/15 07:59 PM
09/26/15 07:59 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
I didn't check every plug wire for spark; one and eight are the ones I checked and spark was there. I'm going to put on an AFB from another car and see what happens. Thanks for the input
Re: CAR BARELY STARTS [Re: frank] #1920238
09/26/15 08:24 PM
09/26/15 08:24 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Have you put a light on it to confirm its correct 5 yrs later ?
Re: CAR BARELY STARTS [Re: frank] #1920293
09/26/15 10:39 PM
09/26/15 10:39 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
What do the plugs look like? I assume they are black from running rich. Sure sounds like it is a flooding/leaky carb issue to me. Does the oil smell like gas?
Re: CAR BARELY STARTS [Re: frank] #1920374
09/27/15 12:42 AM
09/27/15 12:42 AM
tucson az
frank Offline OP
frank  Offline OP
tucson az
Got the car running. I removed the Holley and installed a Carter AFB I had on the shelf for four or five years. Ran two cans of carb cleaner through it, hooked up a fuel line, and the car fired up almost immediately. I obviously did something wrong when I rebuilt the Street Avenger. I drained the oil after about 20 minutes of running and there was a very strong oder of fuel in the oil. Never really liked that SA anyway. I want to thank everyone for your inputs and help, I sincerely appreciate it. Best regards
