Challenger running lights don't work #191962
01/12/09 10:37 PM
01/12/09 10:37 PM
Texas
440maxwedge Offline OP
Texas
Putting back together T/A Challenger, all new harnesses, restored lamps. I have no instrument lights, park,sidemarkers, taillamps, license lamps-nothing. Headlights work, both hi/lo beams. Brake lamps work, turn signals work, backup lamp works. I'm thinking the switch or dimmer for instrument lights is bad? Who makes new e body switches?? Any rebuilders? Thanks
Re: Challenger running lights don't work [Re: 440maxwedge] #191963
01/12/09 11:04 PM
01/12/09 11:04 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Have you tested the fuse?
Re: Challenger running lights don't work [Re: 1_WILD_RT] #191964
01/12/09 11:09 PM
01/12/09 11:09 PM
Texas
Texas
Fuses all new, good. Do all the running lamps go through the same fuse??
Re: Challenger running lights don't work [Re: 440maxwedge] #191965
01/12/09 11:12 PM
01/12/09 11:12 PM
you might pull the connector off of the headlight switch & jump 12V to the park/tail lights etc. I'd be a place to start to pin it down.
Re: Challenger running lights don't work [Re: 440maxwedge] #191966
01/12/09 11:15 PM
01/12/09 11:15 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Yes, new doesn't mean good, I've seen fuses that visually look fine have a failure in the area hidden by the endcap....It's possible you have a minor short that will pops the fuse so just replacing it isn't the best option, instead teast it with a test light...Ground the clip & probe either end of the fuse, it should light at either end, if it light at one but not the other you have a bad fuse...
Re: Challenger running lights don't work [Re: 1_WILD_RT] #191967
01/14/09 04:18 AM
01/14/09 04:18 AM
Iceland
70rtshaker Offline
super street
70rtshaker  Offline
super street
Iceland
Ihad the same problem, bad connection in firewall bulk connection
Thordur Ingvarsson, Reykjavik Iceland 1970 Dodge Challenger R/T 440 sixpack Shaker(sold) 1971 Plymouth Cuda pro-street project 2007 YAMAHA YZF R1 189 HP 2007 YAMAHA FZ1 SA 150 HP 2003 Mercedes Benz E-200 Kompressor 163 HP toti62@internet.is
Re: Challenger running lights don't work [Re: 70rtshaker] #191968
01/14/09 08:58 AM
01/14/09 08:58 AM
30 Rock
JS29 Offline
JS29  Offline
30 Rock
That is what I had.
