Re: 440 plug wire set premade that fits well
[Re: drce2]
#1919639
09/25/15 06:23 PM
09/25/15 06:23 PM
Posts: 2,860 Pattison Texas
CSK
Pattison Texas
fire core will make them to your specs
[Re: CSK]
#1919778
09/25/15 10:37 PM
09/25/15 10:37 PM
RapidRobert
Not what you asked for but just me I would highly recommend a cut to fit set & get em all dead on for exact length. the crimping pliers are pretty cheap. too long or short of wires are problematic & I want enough slack at the dist cap so it will come up just the right amt. and the right lengths for wire seperators/holders etc. If you give Firecore your dimentions be sure to get a long wire and mockup every cap terminal/plug location IN PLACE & get your measurements dead on
[Re: drce2]
#1921024
09/28/15 04:03 AM
09/28/15 04:03 AM
Posts: 43,174 Bend,OR USA
Cab_Burge
anyone have an idea on a premade plug wire set that fits well for a 440? is this a stock car with exhaust manifolds or with headers? It makes a difference usually If a stock car which year and body style?
[Re: 62maxwgn]
#1921496
09/28/15 10:35 PM
09/28/15 10:35 PM
RapidRobert
For Firecore it sounds like you dont need to measure anything, that they have it (the dimentions) down pat!
[Re: drce2]
#1922477
09/30/15 02:18 PM
09/30/15 02:18 PM
Posts: 18,157 Mass
DAYCLONA
Mass
anyone have an idea on a premade plug wire set that fits well for a 440? I've used several sets from Pertronix that fit with no issues on 440/4 and 440/6 (different coil location, Pertronix supplies both coil wires in their set 440/4 or 440/6) this was on vehicles with stock HP manifolds, headers are another issue to consider
[Re: RSNOMO]
#1922776
09/30/15 09:19 PM
09/30/15 09:19 PM
dogdays
Magnecor
The best ignition wires by far. And their Website is closer to real science than most or all of the others.
They are still in business and still pricey. And their sets fit, at least the ones I have used.
R.
