mopar m1 or edelbrock rpm???? #1918238
09/23/15 06:06 PM
09/23/15 06:06 PM
Hawaii
dirtycj5 Offline OP
dirtycj5  Offline OP
Hawaii
i building a mild 360 magnum that will go in my 72 dart.
gonna run a big mutha thumper cam and 750 eddy carb.
what do you guys recomend mopar m1 or the eddy rpm
its a street car 4:10 gears and a 5 speed
Re: mopar m1 or edelbrock rpm???? [Re: dirtycj5] #1918242
09/23/15 06:11 PM
09/23/15 06:11 PM
AndyF Offline
AndyF  Offline
RPM intake is very hard to beat for a street engine.
Re: mopar m1 or edelbrock rpm???? [Re: AndyF] #1918447
09/23/15 10:52 PM
09/23/15 10:52 PM
Hawaii
dirtycj5 Offline OP
dirtycj5  Offline OP
Hawaii
thanks
Re: mopar m1 or edelbrock rpm???? [Re: dirtycj5] #1919118
09/24/15 10:18 PM
09/24/15 10:18 PM
Earth
Rob C Offline
Rob C  Offline
Earth
Ditto. There is good useable torque with the dual plane. The M1 will (or should be) the winner above 4000/4500. (cam size dependent) Use the RPM. The M1 is best suited for a serious drag effort or constant high rpm use.
Re: mopar m1 or edelbrock rpm???? [Re: dirtycj5] #1919245
09/25/15 01:11 AM
09/25/15 01:11 AM
montana
P
pjc360 Offline
pjc360  Offline
P
montana
There is a dual plane m1 as well
Re: mopar m1 or edelbrock rpm???? [Re: dirtycj5] #1919396
09/25/15 12:53 PM
09/25/15 12:53 PM
East Central Illinois
jeff57 Offline
jeff57  Offline
call camshaft company tech line and see what they recommend. they can help you get matched up, if they can't,,,use a different cam company, just a thought jeff57
