Supercuda, you da man!
The pistons happen to be JE. So I called their tech line, got someone right away. I happened to have the original DLI spec sheet for this motor and it had the order number for the pistons. It was from 1996 when they had a couple of replacement pistons made.
It took Darrel awhile to access the old records, but they still had them. Which gave him all the info he needed to spec the rings. And guess what? They had a set on the shelf in Ohio! I should have them by the end of the week.
Thank you very much for the lead. It saved me a ton of hassles.
