Re: snow meth/water injection
[Re: mprhound]
#1917954
09/23/15 11:24 AM
09/23/15 11:24 AM
Posts: 12,307 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
There are RPM and vac thresholds on the Snow that you set. I bought mine used and had a few issues getting it up and running. Snow was very helpful even though I was not the original purchaser and we resolved the problem.
I use mine mainly as an insurance policy. I run a lot of compression on my street car and with the variation in pump gas, the Snow kit keeps me out of detonation territory. I have not re-dynoed the car with the kit, so I do not know if it added anything measurable other than safety.
I used the w/w washer bottle on my Cuda and w/w fluid mixed with HEET as directed in the instructions rather than the expensive Boost Juice.
It has all worked fine for the couple of years that it has been on this car.
Master, again and still
[Re: mprhound]
#1918257
09/23/15 06:31 PM
09/23/15 06:31 PM
Posts: 52,972 Romeo MI
MR_P_BODY
That is what I am looking for, the help to eliminate any chance of detonation I am running 12.7 to 1 compression and using torco accelerator on drag week. So trying to look at all options having to us pump gas. You could very well be ok IF you dont get on it and pull a few degrees of timing during the road travel but if you HEAR any knock then either use the meth/ water or pull more timing... if you hear it, ts pretty bad.. use premium fuel at the pump EDIT your cam makes ALL THE DIFFERENCE... check your cranking pressure
[Re: mprhound]
#1918882
09/24/15 04:42 PM
09/24/15 04:42 PM
Posts: 7,506 Az
Crizila
Az
Has anyone used the snow kit on naturally aspirated carb motor. there site says it uses a vacuum referenced progressive controller. Durability? how well does it work? IMO, Snow is the Cadillac of water injection systems. Almost too much adjustability. Controller has 3 adjustable pots. One for NA or Boost motors, one for water turn on ( when the pump starts to pump ), and one adjustment for max flow ( max pump output). Example: In my case ( I run a boosted motor ) I set the first pot on Boost. The controller is now boost referenced off the fuel regulator ( you will need a fuel regulator with a reference port on the top side of the diaphragm ). Second pot is initial pump start which I set at 5 lbs of boost, Third pot is max injection which I set at 19 lbs of boost. Besides those adjustments, you have 3 different nozzle sizes to chose from. The booklet that comes with the system gives you some initial setting guides. The delux kit also comes with a float kit in the tank for low fluid level ( LED light ) also a LED light to let you know the system is operational. Also includes an anti siphon solenoid in the pump feed line. If you are running pump swill and a high CR #, I wouldn't leave home without one. - and don't kid yourself with the - well, I just won't put the pedal to the floor thing.
Fastest 300
[Re: DaytonaTurbo]
#1918981
09/24/15 06:43 PM
09/24/15 06:43 PM
Posts: 13,406 Marion, South Carolina [><]
an8sec70cuda
Does anyone use one on a 12 or 13:1 engine so they can run pump gas on the street? You would need to be spraying full-time, not just during WOT. No you wouldn't. It will run fine until you romp on it.
[Re: mprhound]
#1918989
09/24/15 06:57 PM
09/24/15 06:57 PM
MR_P_BODY
The reliability is what I am concerned with, on drag week I don't want it going out while I am on the road and leaving me high and dry What is your cranking pressure.. this will tell you a lot
[Re: an8sec70cuda]
#1919018
09/24/15 07:48 PM
09/24/15 07:48 PM
Posts: 12,419 Taxes & Virus's R-US, NY
Dragula
Does anyone use one on a 12 or 13:1 engine so they can run pump gas on the street? You would need to be spraying full-time, not just during WOT. No you wouldn't. It will run fine until you romp on it. Buddy of mine races his Road Runner NA with a 493....Motor is right around 14:1....used to run race gas, runs 93 now with the Snow kit. He's jetted a little fat so his ET is off .1, but says he loves it. Pump gas, still running high 9's and he is slowly leaning it out...No issues with reliability.
[Re: MR_P_BODY]
#1919212
09/25/15 12:15 AM
09/25/15 12:15 AM
Posts: 3,288 West Coast, USA
jbc426
West Coast, USA
The reliability is what I am concerned with, on drag week I don't want it going out while I am on the road and leaving me high and dry What is your cranking pressure.. this will tell you a lot How would 225psi cranking compression do, MR_P_BODY?
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#1919218
09/25/15 12:22 AM
09/25/15 12:22 AM
MR_P_BODY
What is your cranking pressure.. this will tell you a lot [/quote] How would 225psi cranking compression do, MR_P_BODY? [/quote] Not well... really if its above 190-195 your gonna need help or backing the timing WAY off which isnt good either.. a lot will say 200 psi.. but with the fuel now days I dont think so
[Re: MR_P_BODY]
#1919244
09/25/15 01:11 AM
09/25/15 01:11 AM
Posts: 409 Texas
mprhound
Texas
The reliability is what I am concerned with, on drag week I don't want it going out while I am on the road and leaving me high and dry What is your cranking pressure.. this will tell you a lot will have to check cranking pressure, the cam is a Howards solid flat tappet 260@.050 288 advertised .657 lift with 1.6 rockers and I have backed timing down between tracks. These thoughts all came about because I pushed a headgasket out into the water passage this year. replaced it outside of union grove, One of the Great Lakes Dragway crew came by and got us to his house so at least we had a flat place to work (many Thanks to Don). went ahead and pulled both heads and the other gasket was pushed some , just not to the water passage yet. I have been running Torco accelerator additive to premium gas in this motor the last two years, no detonation when the torco used, (one tank this year I was not able to put the torco in because I filled the tank up, had to wait a few miles down the road to add the torco.) I always run premium. That is what led me to think about the water/meth injection to help with the stuff they call gas these days. The torco is expensive and rough to carry for dragweek when compared to water/meth injection. From reading snows website I liked the idea that the controller had set inputs on rpm and referenced that amount of injection via vacuum with tha full amount coming in at a set vacuum level. I figured the pumps should be pretty reliable I was more concerned with the controller, Thanks
[Re: mprhound]
#1919285
09/25/15 04:56 AM
09/25/15 04:56 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
Charley, What head gaskets? If you don't mind me asking...
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: an8sec70cuda]
#1919570
09/25/15 04:42 PM
09/25/15 04:42 PM
DaytonaTurbo
Manitoba, Canada
Does anyone use one on a 12 or 13:1 engine so they can run pump gas on the street? You would need to be spraying full-time, not just during WOT. No you wouldn't. It will run fine until you romp on it. what about if you're having ping problems at part throttle because of a hi-cr? Wouldn't running some water injection at part throttle be better than dialing the timing down to nothing?
[Re: mprhound]
#1919651
09/25/15 06:49 PM
09/25/15 06:49 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
What he said...
Im hoping to start building a car for DW in the near future. Motor is a 470 with BS heads and 11.5 comp. I am dropping the gear to a 3.54 and will be using a 9.5 vert. I too am worried about part throttle detonation...
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: Von]
#1919658
09/25/15 07:07 PM
09/25/15 07:07 PM
MR_P_BODY
What he said...
Sell the carb and put injection on it.. let the computer deal with it... then use a second program for racing OR let the computer deal with some higher octane.. thats what I did on my DW car... but I ran into trans problems this year and didnt make it to DW
