under hood exhaust heat #1917687
09/22/15 09:44 PM
09/22/15 09:44 PM
Atlanta, GA
mgoblue9798 Offline OP
Atlanta, GA
I have a 2002 Dodge Ram 1500 Van. What would be the best way to reduce the under hood exhaust heat? Thought about ceramic coated headers, but there are no full or mid length avail for my application. Not sure shorties are worth $400. Is there a do it yourself coating available for the stock manifolds, or can they be wrapped with exhaust wrap? This is not about looks at all, just reducing the heat under the doghouse.
Re: under hood exhaust heat [Re: mgoblue9798] #1917809
09/23/15 12:31 AM
09/23/15 12:31 AM
Good Ole USA
djw383 Offline
djw383  Offline
Good Ole USA
Wrap the inside, or outside if possible, of the doghouse with dynamat or fat mat mega mat found on eBay.
Re: under hood exhaust heat [Re: mgoblue9798] #1917885
09/23/15 03:26 AM
09/23/15 03:26 AM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
You can also try some aluminum sheets and fab up a couple heat shields. Mount them over the exhaust manifolds and angle them over the top and down the sides to keep the heat from radiating to the top.
Re: under hood exhaust heat [Re: None2Slow] #1917900
09/23/15 09:00 AM
09/23/15 09:00 AM
IN
ahy Offline
ahy  Offline
IN
In general, wrapping exhaust keeps the heat in the metal and shortens life significantly. Wrapped headers will fail fast and it would not help manifolds either. Insulating the dog box itself sounds like a better strategy... or find a way to coat the iron manifolds.
Re: under hood exhaust heat [Re: mgoblue9798] #1917901
09/23/15 09:11 AM
09/23/15 09:11 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Back in the 80s I rebuilt my Dad's dodge class 3 motor home. The factory heat shields were long gone/rusted out by the time I worked on it. Dad used to keep a wet towel on the floor by the gas petal so he didn't burn his feet. I made up 2 heat shields on both sides of the motor and it made a huge difference for the good.
Now there is some good heat shielding materials that are even better than fat mat/whatever the other stuff is called to be installed inside the dog house. Maybe the 2 together?
Re: under hood exhaust heat [Re: mgoblue9798] #1918338
09/23/15 08:40 PM
09/23/15 08:40 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Re: under hood exhaust heat [Re: mgoblue9798] #1918340
09/23/15 08:42 PM
09/23/15 08:42 PM
USA
3
360view Offline
360view  Offline
3
USA
