1968-1970 Rallye Cluster Clips #1916541
09/21/15 05:57 AM
09/21/15 05:57 AM
Missouri
68KillerBee Offline OP
Missouri
Does anybody know where you can buy the clips that hold in the clear lens onto the actual cluster? I've looked without much luck. This is what I'm looking for, just don't want to pay $25 for 9 small clips. http://www.ebay.com/itm/1968-1969-1970-C...17c&vxp=mtr Plus I need more than one set anyway.
Thanks!
Re: 1968-1970 Rallye Cluster Clips [Re: 68KillerBee] #1916890
09/21/15 06:35 PM
09/21/15 06:35 PM
KS
MoparKansas Offline
MoparKansas  Offline
KS
I think they also used those on E-body Rallye clusters as well. Dave Patik at Performance Car Graphics can probably help you out, but not sure he would be any cheaper. Might check Redline Gaugeworks or there was a company in Arkansas that did gauge restorations as well - can't remember their name.
Re: 1968-1970 Rallye Cluster Clips [Re: 68KillerBee] #1916985
09/21/15 08:27 PM
09/21/15 08:27 PM
Washington/Las Vegas
1971 Gran Coupe Offline
put an ad in parts wanted and I bet you will get a response or two, if I knew how many you need I could look as well thumbs
Re: 1968-1970 Rallye Cluster Clips [Re: 68KillerBee] #1917003
09/21/15 08:55 PM
09/21/15 08:55 PM
central P.A.
HEMIDOG 70 Offline
HEMIDOG 70  Offline
central P.A.
Re: 1968-1970 Rallye Cluster Clips [Re: 68KillerBee] #1917080
09/21/15 10:47 PM
09/21/15 10:47 PM
Missouri
Missouri
I just spotted them back in the shed on a set of e body gauges from when my sis got a 71 cuda. But I can't rob them from hers. Gonna search for a set of gauges off our 73 charger and see if it has some. $10 for 4, tough but at least you save a dollar, haha. Thanks for the responses! I looked through a huge grainger book with no luck.
Currently need 18 since I have two clusters to put together.
Re: 1968-1970 Rallye Cluster Clips [Re: 68KillerBee] #1917091
09/21/15 11:19 PM
09/21/15 11:19 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Do you want used one you can clean up and use or are you set on new ones? Did regular clusters use them, cant say that I remember but I have half a dozen of those sitting around.
Careful, your character's showing!
