six pack carb question #1916197
09/20/15 05:31 PM
09/20/15 05:31 PM
Utah, USA
tweeter1 Offline OP
tweeter1  Offline OP
Utah, USA
Getting ready to purchase a Holley six pack carb setup for a big block.
I have heard that some have used the 340 six pack carbs, and some using the 440 center carb and 340 outboard carbs.
I would love to get some feedback, and who is the leading authority here on 6 pac induction.
Thanks for your help
Re: six pack carb question [Re: tweeter1] #1916204
09/20/15 05:50 PM
09/20/15 05:50 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Get the list number off the carbs....
Tony
70 AARCuda Vitamin C
Re: six pack carb question [Re: tweeter1] #1916216
09/20/15 06:10 PM
09/20/15 06:10 PM
Utah, USA
tweeter1 Offline OP
tweeter1  Offline OP
Utah, USA
440 center carb 0-4144-1
outboards 0-4365-1
340 center carb 0-4792
outboards 0-4790
I looked up the numbers Summit
Hope this helps and thanks
Re: six pack carb question [Re: tweeter1] #1916270
09/20/15 07:51 PM
09/20/15 07:51 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
Silly Rabbit, we ALL are of course! biggrin
Re: six pack carb question [Re: tweeter1] #1916572
09/21/15 09:49 AM
09/21/15 09:49 AM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
I put Holley 340 center and outboards on my 383. Mopar Performance reccomended 440 center and 383 outboards for B Blocks, and the only difference I could see between the 440 and 340 centers was the main jets.
I pulled the 61 jets out and installed 63's as reccomended by the six pack tuning tips. Stock '70 383 Magnum, Stock manifolds and 2-1/2" exhaust. Motor runs nicely now. Holleys are about $100 less each than the Mopar Performance carbs, and the 340 center less than the 440. Jets are $6 a pair.
http://www.mopar1.us/6barreltips.html
Re: six pack carb question [Re: tweeter1] #1916736
09/21/15 02:50 PM
09/21/15 02:50 PM
Buy the BB carbs, do not mixed them with the SB smaller center carb, you will always be sorry if you do tsk twocents remeber that BB love air and fuel, more air and fuel, more power up the right foot determines how far the carbs. open up to wide open throttle work shruggy grin I love six paks up
Re: six pack carb question [Re: tweeter1] #1916780
09/21/15 03:33 PM
09/21/15 03:33 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
I thought the center carbs were the same CFMs, at least the factory carbs, am I wrong?
Careful, your character's showing!
Re: six pack carb question [Re: mopar346] #1916833
09/21/15 04:58 PM
09/21/15 04:58 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
Re: six pack carb question [Re: mopar346] #1917095
09/21/15 11:23 PM
09/21/15 11:23 PM
I'm sure that the stock 1970 340 carbs, automatic and stick shift, CA and non CA carbs. flowed 300 CFM from Holley on Mopar production 340 C.I.motors, not 350 CFM like the original 1969,1970 and 1971 model productions OEM 440 carbs did shruggy I know several NHRA stocker racers that had a bunch of different original OEM 340 and 440 carbs, none of them ever said that all the center carbs. they had flowed (a bunch of them) for both motors flowed the same for the BB and SB motors work In fact, I've seen stocker racers switch the center carbs. after qualifying at NHRA major races, before being tech. or sealed up for tech. work shruggy Lots of misinformation out there shruggy
Re: six pack carb question [Re: tweeter1] #1917103
09/21/15 11:29 PM
09/21/15 11:29 PM
mopar346 Offline
mopar346  Offline
Cant tell you about actual flow numbers but pretty sure they were advertised as the same. I am reasonably sure the 440 pulled more from the secondaries than the 340 pulls.
Re: six pack carb question [Re: tweeter1] #1917211
09/22/15 03:03 AM
09/22/15 03:03 AM
WA
tman Offline
tman  Offline
WA
Re: six pack carb question [Re: tman] #1917313
09/22/15 11:51 AM
09/22/15 11:51 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Originally Posted By tman
And some incorrect information .
